Search the Community
Showing results for tags 'zero oil pressure'.
  • Search By Tags
    • zero oil pressure ×
  • Search By Author
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Found 1 result
  1. BRAT 85 1.8 engine. After retrieving from three months storage the oil pressure cage stays at zero. Prior to storage it would go up to 30 when cold and drop to 15 when warm.. with the sender disconnected gauge reads 0 lead shorted to ground gauge goes to max. Ohm meter on sending unit shows in...
