89 spfi wagon wont idel when cold
I had the wiring go bad to the IAC - would not idle unless you held your foot on it until it warmed up, and would die at stops sometimes. Had to run a new line from the connector at the driver's fender to the valve. Test everything!
now that sounds just like my problem, with out stalling at stop signs, today it started to go crazy at like 3500 rpm so i took out a huge wrench and beat that idel control valve and it started to come down to normal. maybe that thing is bad? ill test some stuff tomorrow after work thanks
matt
