Yes, it would sound like it doesn't have any compression. Turn over a bit faster. But since your engine is non-interference the pistons and valves will never come into contact. So you won't hear any nasty noises if your timing belt breaks.
I'll check the timing belt next, but it sounds the same when it cranks. Does'nt this sound like a spark issue? I pulled #1 plug and when grounded and cranking...no spark. I guess I should have said this first but didn"t want to rule any sugestions out. I relize if timing belt was broken I'd get no spark so I'll check that and get back to you.
Thanks again!
fatguide
2 things I can think of are the Ignitor/Igniter (?) - dead center on the engine side of firewall, and the coil pack, including the plug that connects by the throttle body.
Not sure how to test either, but I know they'll keep it from firing.
Checked for Codes (CEL)? - Instructions HERE.
