2.5 turbo into an outback...
vwbuge1
It will bolt right up to the bellhousing, but everthing else...
I take it you have a 2000-2004 Outback, which might make things easier since that's what the Baja is based on. You will need a turbo cross member (probably from a Baja), Baja ECU, wiring harness, and exhaust manifold. You should also get yourself a baja hood for the intercooler. It's going to be just like a 'standard' STi swap, which means the wiring is going to take some time.
