donnieru Posted September 19, 2009 Share Posted September 19, 2009 Hi!! Thanks for reading this. I have a 91 Loyale EA-82 spfi 5 speed 2wd. i had my cam case off the other day and when I pulled the 4 wire plug off the disty I noticed that while it was color coded it had 2 of the wires reversed in the plugs. It has red, black, green and a whitish yellowish one. the green wire runs into the white and the white runs into the green. Is it supposed to be this way or is it supposed to go to the same color? Link to comment Share on other sites More sharing options...
GeneralDisorder Posted September 19, 2009 Share Posted September 19, 2009 Does it run? Very often wire colors change when going through harness connectors. GD Link to comment Share on other sites More sharing options...
donnieru Posted September 19, 2009 Author Share Posted September 19, 2009 Yep it runs. It just looked strange to see the wires run like that so I figured I would ask someone smarter than I am lol. I saw it when I put the engine back together but I hadn't found this site then. When I pulled the cam case off it jogged my memory and I thought I should find out for sure. Only running issue it has is hesitation from launch to about 1600 rpm. Idles a little rough also. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted September 19, 2009 Share Posted September 19, 2009 Only running issue it has is hesitation from launch to about 1600 rpm. Idles a little rough also. Both classic symptoms of a vacuum leak. Spray around the manifold and hoses with carb cleaner - when you find a leak the engine speed will increase for a short time. GD Link to comment Share on other sites More sharing options...
donnieru Posted September 20, 2009 Author Share Posted September 20, 2009 Thank You GD. Glad to know that it isn't going to be a issue. I am going to replace all my vac .lines make sure everything is nice and tight. Link to comment Share on other sites More sharing options...
