bgambino Posted September 19, 2009 Share Posted September 19, 2009 02 legacy GT Have speedometer cluster semi-apart to change bulbs that illuminate gas gauge,speedo tach etc (one is out...figure I'll change all) Take a look at the pic...aside from the blue condom slipped over the bulb, they look like a standard bulb (these were used in the front subaru corner parking lites in older models) OR...are these something special??? Please, no guesses...I don't want to take the dash apart again thanks Link to comment Share on other sites More sharing options...
OB99W Posted September 19, 2009 Share Posted September 19, 2009 What number(s) is/(are) imprinted on the original bulbs? Link to comment Share on other sites More sharing options...
Fairtax4me Posted September 19, 2009 Share Posted September 19, 2009 (edited) There is usually a number imprinted somewhere on the bulb. There are at least 3 bulbs that are the same dimensions as what you have pictured, but the wattage is different between them. They may output more or less light than the original bulbs if you use the wrong ones, so you should make sure you get the correct bulbs. Sylvania has a replacement guide on their website which is useful in most cases. But they don't list an instrument panel bulb for your car. http://www.sylvania.com/ConsumerProducts/AutomotiveLighting/LampReplacementGuide/ edit: Found a listing on GE's website. Should be a 168 http://genet.gelighting.com/LightProducts/Dispatcher?REQUEST=CONSUMERAUTOMOTIVE&CHANNEL=Consumer&APPLICATION=Automotive&CATEGORY=Lamps Edited September 19, 2009 by Fairtax4me Link to comment Share on other sites More sharing options...
987687 Posted September 19, 2009 Share Posted September 19, 2009 I went to napa and asked for the bulb. It is listen in their computer system as to which one you need. Link to comment Share on other sites More sharing options...
bgambino Posted September 19, 2009 Author Share Posted September 19, 2009 well...the only place i have available tomorrow is carquest we'll see if they carry that kind if info anyone know if all 4 (or 5,,not sure how many are back there) are identical at least? Link to comment Share on other sites More sharing options...
987687 Posted September 19, 2009 Share Posted September 19, 2009 on my car they aren't. There are 2 different sizes. if you pull them all out it will be obvious if they are all the same or not. Link to comment Share on other sites More sharing options...
