I HAVE A 2003 FORESTER. aLL ALL FORESTER EQUIPPED WITH THE KEYLESS ENTRY, EVEN THOUGH YOU DO NOT GET THE REMOTE IN THE X MODELS? IF NO WHERE ON THE CAR IS THE KEYLESS SYSTEM TO SEE IF MY CAR IS SET UP FOR THE KEYLESS ENTRY, BEFORE I PURCHASE A NEW REMOTE.
http://www.cars101.com/subaru/forester/forester2003.html
03 was a major make-over for the Forester
a few things new on all models
All new Dashboard
All new Center console re-designed with 2 cupholders
Hill holder clutch is back! (manual only)
Side airbags standard on all models
Dual stage deployment front passenger airbag
Aluminum alloy hood (lighter weight)
Aluminum alloy rear gate (lighter weight)
Counter balanced glove box (easier open)
Dual vanity mirrors
Dual overhead console bins
Fuel door release lever
Larger disc brakes
Illuminated power window switches
Accessory plug in console plus dash lighter plug
Re-designed driver's seat with greater height adjustment range
Tilt wheel has larger range
No passenger door key, key works on driver's door only (and remote entry is std on all models)
new on X (only $250 more than 02 L)
X model replaces L
16" wheels (were 15")
Keyless remote standard (was optional)
Variable delay front wipers (replaces single speed)
Rear window wiper de-icer
CD player/AM/FM/Weatherband standard (no cassette avail)
ok, i have a remote, when i follow the instructions, about turning the switch from off to on 10 times, the horn does not sound. i have tried it several time even a few more time waiting for the horn to work, nothing. i did notice when i manuall locked the doors, with the door lock, when closing the door i heard a mild chirp and the park lights flashed. i just cannot the horn to sound when turning the switch. any suggestions, or what am i doing wrong.
