81 passing lamp...
2.5GL
Want to know if there is a control unit for the lamp, if so, where is it located on the car? The light works, door does not open. Checking continuity of motor in the mean time...
All other aspects of system work, dash lights, switches, etc.
on the dash , near the turn signal lever down where there is a hole on the dash on the flat part of it, near the light switch.
the relay is on the passenger right shock tower with all the other relays....it has a pink connector with like 5 or there abouts wires....
You might also try re-soldering the one of the connections on the front of the motor itself. The door on my '81 stopped opening and I re-soldered the green wire IIRC, and it works great now. If I am not mistaken this is a common problem on these units. Just disconnect the battery because at least one of the wires is hot.
  • 3 months later...
:grin: ^ +1 This is the problem most of the time... though I did have the motor housing crack open on me once!
Any luck with fixing your passing light door? I've got the
same problem, light works, but door isn't opening.
Will follow these recommended checks, but I wanted to know if
you had any luck w/yours?
Any tips?
Thanks much
Nothing yet (that I know of), Little bro has his car now, but I am uncertain if the light was ever fixed before he picked it up. They have the info from here on how to go about fixing it, I'll leave it up to them to figure it out.
Thanks!
L
  • 4 weeks later...
'81 4x4 wagon w/passing lamp
I got busy trying to fix my passing lamp yesterday, but ran outta daylight
before I could completely remove it.. (front bumper will have to be removed
before i can pull it).
My light works, but the door/cover will not open. My question to those
who have a functional lamp would be this..
Should I be able to open the lamp door by hand, by rotating the lever
behind the motor? If so, then I believe mine to be frozen up, but if
not, then maybe I just have the 'bad solder connections' on the front
of the door motor... The most common 3rd-eye failure, according to other
USMB users..
. Oh, and the clear vacuum hose attached to the 3rd eye door motor isn't connected on
one end; is simple pinched over and zip tied to the sheetmetal bracket.is that
correct?
any help will be appreciated. that light is too cool not to work properly!! ;)
anyone have parts for sale?:)
thanks,
gadberry
Edited by gadberry
