I used a polishing compound that came in a yellow bottle with a buffing pad for a drill on my daughter's 93 Legacy. Made alot of difference in the brightness of her headlights. Do not use a rubbing compound as it would scratch the lense, the polishing compound is white and has no grit to it. Glenn Taylor.
  • 9 months later...
I did not have good luck using polishing compound. What I did was to use a razor blade and with moderate pressure scrape the yellow plastic off the lens. You can see the shavings are yellow. When done I buffed the lens and saw noticable improvement.
If you do not want to pay for polishing compound, you can go to a discount store and buy some cheap toothpaste (the paste type, not the gel type) and apply with a soft cloth and elbow grease. Essentially the same stuff as the compound, and cheaper too! (This also leaves your headlights smelling minty fresh :grin:)
I read this thread today and tried it on my tired, '90 Legacy lights...It WORKED GREAT!!!!! File this under why the fuq did I just learn about this now? I cleaned the dirt off them first then rubbed brake fluid on them and dried them. It took maybe 5 min for both and they really look brand new I'm shocked.
So, this may be a stupid question, but did you all do the inside surface as well as the outside? I tried prying a clip off my headlight to get to the inside and the plastic clip just shattered. I stopped there. If it's not necessary I won't even try it.
No, that's a great question...I only did the outside.
