stop there. By the way brake fluid can damage paint so be careful with it.
Yea. That's probably part of the answer to my question above: what's the physics or chemistry of brake fluid effectiveness as a plastic cleaner and polisher?
It's probably the same brake fluid chemical ingredient that disolves paint and that eats at plastic oxidation (yellow).
I tried to use brake fluid as a paint remover once (needed to clean a spot for an electrical ground connection). I didn't do anything! Either Volvo paint is immune to brake fluid, or Castrol LMA doesn't damage paint. Haven't tried it on my Sube.
A pal of mine told me that the best trick for yellow headlights is CLR
I happen to have some CLR, brake fluid, yellow headlights, and some time this weekend. I'll give it a shot and let you know next week how it goes. I wonder what happens if you mix CLR and brake fluid? Anyone else want to take on that task?
Well, I tried just now some prestone brake fluid (dot 3) that I had on the shelf. It seemed to be taking off a layer of roughness with some elbow grease, but now the lenses appear to be cloudy... any suggestions here? (96 outback 5 spd... 175k)
thanks
badjer
Nothing like replying to yourself. It snowed here this weekend, temps fell in to single digits. No garage so I didn't try it. My dedication declines with the temperature. I'll just drive during daylight hours or tailgate someone with decent headlights until the spring thaw. I could just duct tape a mag light to the hood, probably provide better light at this point anyhow.
