heater help
shep_11
85 gl wagon
My blower motor doesnt run at all. Checked the plug going into blower motor and no voltage. Took instrument bezel trim off to check the actual switch. But im not sure what to check to see if its working correctly. And What are those little fuse looking things with round ends?ry%3D400ry%3D400
theres one white one, one blackish one, and one is empty.
Thanks,
Wes
I have discovered the problem to be the blower motor relay, i had to have them order it, in the meantime i need to check the motor. Can i just run a hot wire off the cigarette light and touch it to where the plug went into the motor, and if the motor is good, it should spin right?
Thanks,
Wes
