Single Row ea81 radiator?
tforce
Did they make a single row ea81 radiator? If so, will it provide enough cooling for an ej22 swap and does anybody have one?
I can't even get my ea81 skinny fan in between my radiator and engine. I really don't want to have to remove the hood latch and put the fans in front of the condenser if I can avoid it. Maybe use an ea82 single row?
Mine is a single row and it has been cooling alright thus far. For fans I mounted two 10" electric ones in the front and ditched the AC condenser. Seems to work pretty good, I just didn't have room to mount the antifreeze overflow tank where it normally goes on the side of the fans.
Is it an ea81 radiator? What year/make is it out of? I'm keeping the AC which is why I'm looking for a single row. My skinny fan should fit fine with a single row.
  bheinen74 said:
ej engines run a lot cooler than a ea engine in my observation, with proper cooling, should be good with a new single row and the ej
Thanks. Now I just need to find a used one....new is not in my budget right now.
Am I right in assuming that you are implying that they did make a single row radiator for the ea81?
  GeneralDisorder said:
Have you tried the EA81 auxilery electric fan used on models equipped with AC?
Ya, I have one but even it won't fit between the engine and radiator. I'm trying to avoid removing the hood latch so I was thinking about retrofitting an ea82 single row radiator to fit.
