vwbuge1 Posted September 27, 2009 Share Posted September 27, 2009 Coming up with a catalyst below efficiency code and was thinking of starting out with new o2 sensors before I replace the cat. Does anyone know how many wire the o2 sensors are offhand? 2000 Outback Limited. Link to comment Share on other sites More sharing options...
Log1call Posted September 27, 2009 Share Posted September 27, 2009 You could try testing them with an electrical gauge before buying new ones. Link to comment Share on other sites More sharing options...
davebugs Posted September 27, 2009 Share Posted September 27, 2009 Wherever you're buying them from will know. You can do some searching here. For one of them folks have had luck with the generic ones, for the other not so much luck. I usually have used ones. And if none of them work I go new OEM and am done with it. My soldering skills are a bit challanged. And the last thing I wanna be doing is playing with expensive cats because I'm not getting the correct info from an O2 sensor. But that's me. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted September 27, 2009 Share Posted September 27, 2009 If you just want rid of the code, then install a spark plug non-fouler between the second O2 and the cat. Your cat is probably bad. GD Link to comment Share on other sites More sharing options...
Fairtax4me Posted September 27, 2009 Share Posted September 27, 2009 Grab some from a junkyard. Most U pull its only want like $5 for an O2 sensor. Link to comment Share on other sites More sharing options...
