Wherever you're buying them from will know.
You can do some searching here. For one of them folks have had luck with the generic ones, for the other not so much luck.
I usually have used ones. And if none of them work I go new OEM and am done with it. My soldering skills are a bit challanged. And the last thing I wanna be doing is playing with expensive cats because I'm not getting the correct info from an O2 sensor.
But that's me.
