hebrewhammer Posted September 27, 2009 Share Posted September 27, 2009 95 impreza wagon ej18 5mt awd none of the nobs except for the fan knob work in my impreza. the heat is set around medium and the temp knob doesn't do anything. also the level knob doesn't work either but it is set on defrost. the knob will turn through the different levels but does not switch anything. what is wrong, is there an electric controll unit that is screwed? or is there some linkage i can reach up there and move to put the heat to HOT? Link to comment Share on other sites More sharing options...
lmdew Posted September 27, 2009 Share Posted September 27, 2009 Look on both sides of the center tunnel up front under the dash. The cables may not be connected or the control panel could be bad. The passenger side controls the heat The drivers side controls where the air is going Link to comment Share on other sites More sharing options...
