A/C won't run after driving car for a while when raining??
This problem is really annoying. Just wondering what would tell the AC not to cycle on? Although on a normal hot day driving with AC on I experience no issues, yet when humid AND NEEED TO DEFOG WITHOUT MELTING THE CAR!! Won't turn on unless I leave the car off for 30+mins. What sensor could be bad and telling the AC not to turn on? What does that sensor behind the glove box do going into the heatercore btw?
Sounds like it could be the compressor going.
Try jumping the pressure switch at the dryer, also check for bubbles
Try jumping the compressor relay in the engine compartment fuse/relay box.
If it kicks in with the pressure switch, you need to service the system
As with most things AC, 1st step is to get real AC gauges on the system. this will tell you everything you need to know (like low coolant, too high, bad compressor etc etc etc).
I dont know why everyone wants to skip this first step.
nipper
Strange, isn't it, Nipper? Get that all the time in the shop, too.
Notice how no one has suggested a slipping belt either?
rain makes a great lubricant.
People need to start off with the cheap fixes first, they always seem to go for the most $$$
lol today again works at the beginning steady, but as soon as 3 or so hot restarts with a few minute rests the AC won't work seems like it has to do with engine bay heat. My dad has to get adapters so he can hookup his gauges (hes i HVAC hehe) anyway ill tell you guys whats up, jumping the pressure switch sounds like a good test.
