89Ru Posted September 30, 2009 Share Posted September 30, 2009 What tires fit on the '95 outback wagon without interference? Stock 195/60R15, offset 55mm Stock struts and brakes 205/55R16 2 mph low speedo 205/50R16 accurate speedo Link to comment Share on other sites More sharing options...
89Ru Posted October 3, 2009 Author Share Posted October 3, 2009 16x6.5 WRX wheels (offset 55mm) barely fit the '95 obw with Michelin Harmony 205/55R16. clearance to front strut 7/32" clearance to rear strut 1/4" Any issues with the tight clearance between the tire and the lower strut flange? stock wheels 16x6 Link to comment Share on other sites More sharing options...
johnceggleston Posted October 3, 2009 Share Posted October 3, 2009 (edited) 16x6.5 WRX wheels (offset 55mm) barely fit the '95 obw with Michelin Harmony 205/55R16.clearance to front strut 7/32" clearance to rear strut 1/4" Any issues with the tight clearance between the tire and the lower strut flange? stock wheels 16x6 this tire is .68 inches larger diameter, that's .34" (almost 3/8s inch) more on top (and bottom), than the 95 leg stock tire, 185/70/14. (when they rub, it's only rub on the top half never on the bottom. ) the 97 legacy GT stock size is 205/50/16, it is slightly smaller than yours and a 'smidge' smaller than the 185/70/14, just over 1/8" diameter. i don't think the width is an issue unless you get too tall, i have heard of someone running 225s 'with very little rubbing' but i don't remember if it was a legacy L or an outback. Edited October 3, 2009 by johnceggleston Link to comment Share on other sites More sharing options...
89Ru Posted October 3, 2009 Author Share Posted October 3, 2009 Thanks. I don't think 225's would fit on mine without burning rubber, that's 0.4" wider than the 205's. Reason for changing: The stock rims corrode pretty bad and the bead eventually leaks, the newer wheels don't appear to be coated so possibly salt doesn't work its way underneath and fester...just a guess and off topic Link to comment Share on other sites More sharing options...
89Ru Posted November 24, 2009 Author Share Posted November 24, 2009 WRX wheels fit great on the wagon. So I'm taking this car in for an alignment to correct some minor odd tire wear. I'm assuming that since the overall wheel size + tires is the same, I don't need to request some special type of hybrid alignment, even though the tire width has gone up from 195 to 205. Any issue with wheel bearings? Link to comment Share on other sites More sharing options...
Suzam Posted November 24, 2009 Share Posted November 24, 2009 I've had a set of 2002 WRX wheels on a 95 Legacy L sedan and currently on a 97 Legacy L wagon. Never had a clearance issue with the 205/55/16 size. Never a problem with strange wear or on alignments, no special adjustments needed. Link to comment Share on other sites More sharing options...
89Ru Posted November 25, 2009 Author Share Posted November 25, 2009 Thanks. Good to know since I just did the same WRX wheel swap on the OBS. Now to figure out why the wagon has a noise like a wheel bearing from the rear while driving straight, goes away when in a hard turn. Link to comment Share on other sites More sharing options...
Gloyale Posted November 25, 2009 Share Posted November 25, 2009 Thanks. Good to know since I just did the same WRX wheel swap on the OBS. Now to figure out why the wagon has a noise like a wheel bearing from the rear while driving straight, goes away when in a hard turn. Wheel bearing. Typical for the sound from them to change when loaded/unloaded by weight shifting in turns. IIRC, outback tire size is 205/70/15.....althoug 95 outbacks don't have the body lift so it may have come with 195/70/15 Link to comment Share on other sites More sharing options...
Dickensheets Posted November 26, 2009 Share Posted November 26, 2009 I have a 97 OBW and have run 3 sets of 225/60/15 (BMW tyres). WHY? The diameter is about 3/16th less than stock, however, the speedo is basically accurate. +-2%. The real reason is the handling. It's a lower profile (less sidewall) so it feels WAY more planted coming into the offramp. I have to really try to get it to squeal. Really try. Also I live at 5000FT elev. and in my tiny brain the overall lower gear ratio helps my non-turbo EJ25 wind out better. More HP at lower speed if you will. Keep in mind it's a tiny difference. Later Link to comment Share on other sites More sharing options...
89Ru Posted November 26, 2009 Author Share Posted November 26, 2009 Thx for confirmation on the wheel bearing. 95 stock is 195/60/15 iirc, lowered body style. So I'm 500 miles from home and no tools. Gotta decide if the wago will make it back or burn something up along the way. 164Kmiles. From the sounds, huge guess here but its 'early' in its failure mode considering I noticed it halfway on the front side of the trip, and its still hard to hear. Link to comment Share on other sites More sharing options...
Dickensheets Posted November 26, 2009 Share Posted November 26, 2009 Keep driving. Good luck. Link to comment Share on other sites More sharing options...
