  86subaru said:
looking at a 2000 legacy L wagon , what motor should it have in it, 2.5 or 2.2 , i have not seen it yet , thanks
http://www.cars101.com/legacy2000.html
ALL NEW 3rd generation Legacy Brighton, L, and GT
"All Legacys have the more powerful Phase II 2.5L SOHC 4 cylinder Boxer engine first used in 1999 Forester and Impreza RS. There is no 2.2L engine in the Legacy anymore"
No the 2.5 out of a pre 2000 outback will be the dual overhead cam 2.5. Though this engine will bolt up the intake and all computer controls are totally different. The 2000 legacy has what is called a phase 2 engine. Its a single overhead cam 2.5. Does the one you are looking at have a bad engine? Rod knock. I know a couple junkyard here in columbus that are reliable that have the phase 2 2.5 engines.
no rod knock , runs great , needs brake work, no hg problem, the other motor from another subaru [ 97] had the rod knock, could you look around the yards for a drivers side rear tail light, for a 2000 legacy, + whole rear white hatch, thanks
  torxxx said:
weird.. my moms 2002 lego has a 2.2 in it not the 2.5..
I wonder if its an option?
I know the wagons, with 5 speeds, in the L trim level, could be had with the 2.2, at least into 2001...... Not sure about after that???? All the sedans that I have seen of this vintage were 2.5's. Regards, Steve
