lastchance Posted October 3, 2009 Share Posted October 3, 2009 It's an 84 turbo wagon, btw... Fuse is good. I checked the fusible links under the hood (don't know if they're related to the fan/heater) and they're fine. What's next??? I read in other threads on ea82 cars there's a relay under the dash, near the steering column...Are there the same relays on my ea81? TIA Link to comment Share on other sites More sharing options...
ivantruckman Posted October 3, 2009 Share Posted October 3, 2009 most likely the relay above the fuse panel, i don't have a ea81 here to look at, but i think there similar Link to comment Share on other sites More sharing options...
lastchance Posted October 3, 2009 Author Share Posted October 3, 2009 Sweet! I'll check it out when I get home, if I need a new relay I can probably just scoop one up at the yard, right? Link to comment Share on other sites More sharing options...
lastchance Posted October 13, 2009 Author Share Posted October 13, 2009 So...On the turbo wagon there are only 2 relays, both the same model/part number. One is for the headlights and the other is for ???? I switched the two to make sure both relays are working and they are, I just don't know what the other socket is for. Anyone know? Link to comment Share on other sites More sharing options...
crazyman03 Posted October 13, 2009 Share Posted October 13, 2009 i had a similar issue. i ended up tracing the wires from the fuses to the relay. 'corse, the relay was fine, the blower motor was seized.. i banged it a bit and it works occasionally . -J Link to comment Share on other sites More sharing options...
lastchance Posted October 13, 2009 Author Share Posted October 13, 2009 Haha, AWESOME! Maybe I'll try to hunt down the blower motor! Link to comment Share on other sites More sharing options...
ivantruckman Posted October 13, 2009 Share Posted October 13, 2009 Hmmm not sure about a T-wag, only 2 relays , maby some T-wag owners will chime in...bump Link to comment Share on other sites More sharing options...
bratman2 Posted October 13, 2009 Share Posted October 13, 2009 If you have a portable 12v power source, lawn mower battery etc. Try jumping the connector out to the fan. On my 87 brat it is behind the right passenger side kick panel. That will tell you if the fan works. Link to comment Share on other sites More sharing options...
