stinger44 Posted October 3, 2009 Share Posted October 3, 2009 Hi, noobie here. Anyone have information on the width dimensions on the 2010 Legacy 3.6R (17") wheels? OEM tire size is 225/50-17s. BLUF, I want to put 235/45-17 tires on this bad boy and wanted to make sure they would fit. Tirerack says the wheel width has be between 7.5" - 9.0" to fit those tires. Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted October 8, 2009 Share Posted October 8, 2009 http://www.cars101.com/subaru/tiresandwheels.html says Subaru LEGACY Tires and Wheels 2010; all with Tire Pressure Monitoring 3.6R (all)- 17" alloy wheel 17.0j offset 48 (1.89), PCD 100mm (3.94") Doesn't say a width but it seems like it probably falls in that range you mentioned; that's a pretty good range. Quote Link to comment Share on other sites More sharing options...
