Need a new tranny! HELP!
I got a 2000 Subaru Legacy L! My a/t transmission seems to be fine, but my something wrong with my transfer case/front diff. I found a 2000 legacy outback transmission (TZ1A4ZCABA-WL) but it doesn't exactly match my tranny numbers (TZ1A4zCACA-WR). I know that it will probably fit and bolt up, but I am not sure if the transfer case/front differential will work well with my car. Someone had told me that you need to match those numbers exactly, but I heard that people put Impreza transmission onto Legacies as well as some 2006 legacy transmission work with 2000 legacies. Can anyone help?
I was also wondering what other a/transmissions will fit onto my 2000 Subaru Legacy L and work well?
PLEASE HELP!!!
Thanks!
Yeah thanks! I posted in there and they recommended me to post in other locations as well. The gear ratios are find as far as i know. Someone told me that there might be some slight changes in the transfer case which would cause minor issues because my rear diff is original. Is this true?
