'87 vs '89 SPFI ECU compatability
Has anyone tried replacing an '87 SPFI ECU (22611 AA200 / MECF-011 / xxxx 3E / N) with
an '89 SPFI ECU (22611 AA392 / MECF-022 / xxxx 4E / 42)???
(ECU label differences hi-lighted in red)!
The ECU plugs appear to be the same.
1) Are the pin outs the same? (I have info for '89 but not '87).
2) I know there is an extra sensor (EGR gas temp) on the '89 intake manifold. It is wired (w/r) to ECU pin 38. Unplugging it does not seem to make any diff. - no CHECK ENGINE or ECU codes. '89 FSM says it should cause code 55 (California only - which this car is) for open/short, but it doesn't happen!
The rest of the stuff on the engines looks to be the same although one or two sensor electrical connectors are different.
  GeneralDisorder said:
All the SPFI ECU's are interchangable. Some will recognize the EGR temp sensor and some will not. Doesn't matter for the functionality.
Wow, that's very good to know. I searched and searched before posting and found very little info about ECUs.
Thanks for the prompt reply.
TF
