jrettenmayer Posted October 6, 2009 Share Posted October 6, 2009 Does anyone know anything about using the Ford F-series fuel pumps on the EA cars when doing a EJ22 swap? Any specific pump I'm looking for? Link to comment Share on other sites More sharing options...
torxxx Posted October 6, 2009 Share Posted October 6, 2009 Ford F-series = pickup fuel pumps. They are mounted in the tank, so good luck with that. Use a turbo EA82 fuel pump instead Link to comment Share on other sites More sharing options...
jrettenmayer Posted October 6, 2009 Author Share Posted October 6, 2009 I know what F-series means... I'd imagine that some of the older F-series had pumps NOT mounted in the tank - I read on this forum someplace about using just such a pump. Apparently they are cheaper than replacement pumps for a Subaru, so I thought I'd look into it. Thanks for the opinion. :-\ Link to comment Share on other sites More sharing options...
GeneralDisorder Posted October 7, 2009 Share Posted October 7, 2009 (edited) Correct - older F-Series and Bronco's used frame rail mounted pumps. I don't know the exact years but there are thread's here that detail exactly which one's you are looking for. One of the part numbers mentioned in the old posts is a NAPA #2p74028 which is a frame rail mounted high pressure F-Series pump. Back in the early years they used an in-tank pump to pull the fuel to the high pressure pump mounted on the frame rail - this is one of those. IIRC from old posts it's something like 90 psi capable - which is far more than any Subaru engine needs. GD Edited October 7, 2009 by GeneralDisorder Link to comment Share on other sites More sharing options...
jrettenmayer Posted October 7, 2009 Author Share Posted October 7, 2009 Thanks GD... any reason why this one wouldn't work? http://www.napaonline.com/MasterPages/NOLMaster.aspx?PageId=470&LineCode=BSH&PartNumber=N69404&Description=Fuel+Pump+-+Electric+In-Line+Type Link to comment Share on other sites More sharing options...
bobjr94 Posted October 7, 2009 Share Posted October 7, 2009 Ive worked on those 86-90ish fords with the 2 fuel pump setup, one had a bad fuel pressure regulator and was running about 90lbs of pressure. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted October 7, 2009 Share Posted October 7, 2009 jrettenmayer said: Thanks GD... any reason why this one wouldn't work? Yes - that's a low pressure pump. It lists 5 to 9 psi. The EJ engines need about 35 psi. You must use a high-pressure fuel injection pump, not a transfer pump or a carbed pump. GD Link to comment Share on other sites More sharing options...
jrettenmayer Posted October 7, 2009 Author Share Posted October 7, 2009 Ok, that makes sense. I thought I remembered hearing from someone on here EJs need around 10 PSI, but I'm sure I'm wrong about that. The hose barbs on the NAPA #74028 pump mate are the correct size, I take it? Link to comment Share on other sites More sharing options...
GeneralDisorder Posted October 8, 2009 Share Posted October 8, 2009 jrettenmayer said: The hose barbs on the NAPA #74028 pump mate are the correct size, I take it? No idea. Probably not. Nothing that can't be corrected with some brass hose barbs. GD Link to comment Share on other sites More sharing options...
WoodsWagon Posted October 12, 2009 Share Posted October 12, 2009 I run 2 of them, one on my 92 EJ22 swapped loyale and one on my 86 turbowagon. The pumps are a fair bit louder, but for $90-100 bucks it's not bad. My loyale had no carpets so it was louder anyway. You need to adapt from the 1/2" or so coming from the fuel tank to the 1/4 or 3/16 that feeds the pump. You will also need to splice spade connectors onto the pump wiring harness to fit the ford pump. I have had a small tree pull one of the wires off before but my pump is not well protected. Link to comment Share on other sites More sharing options...
