transmission computer impreza 1994
My impreza has broke down the transmission computer. Part no. 31711ac750 A64000 DE1
WHAT CAN I DO ??????
WHO CAN HELP ME TO GET IT ?????
CAN I USE THIS COMPUTER ?????? IMPREZA 1995 COMPUTER PART NO. 31711 AC911,A64-000 DM4
Thanks...I apreciate your help.
what makes you think the computer is bad.?
i don't know for sure the computer listed will work but i bet it will, matbe not perfectly. if you already have it, try it. you won't hurt any thing. what car is the new one out of, do you know? the closer the car match is the better the chance it will work.
on the legacy side, a legacy trans will run on a outback computer and vice versa. same for a GT.
Edited by johnceggleston
TCu's rarely fail....like almost never.
which means two things. first - are you sure it's bad?
second - get a used one.
make sure everything matches - FWD/AWD/EJ18/EJ22
I'm not sure but 91-94 should be interchangeable
95-98 are be interchangeable.
not sure about interchanging between those groups.
In a sense the engine size doesn't even matter, they are interchangeable as well (i've done it), but probably best to match yours for performance, shift characteristics, etc.
