will the heads from an ea82 block work on an ea82t?
okay im confused. if my block were a true EA82T would it have the "T" stamped on it? because it doesnt. The car is a 1989 Gl-10 AWD Turbo, it has all the badging, all the gadgets. To the best of my knowledge, the motor is original. I just ordered a set of remanufactured heads off of ebay and it says they will work on a EA82T. If i transfer the cam carriers from the old heads to the new will they work? and the reason i ordered two new heads is because the passenger side (turbo side) has one of the bridge cracks that goes all the way down into the runner = no go. And the drivers side head has a very badly stripped spark plug hole and a bridge cracks forming as well. I have access to a bridgeport and lathe in my uncles garage where the work will be taking place. Possible modification to new heads for an oil feed line?
