backinbrat Posted November 8, 2009 Author Share Posted November 8, 2009 Uberoo said: when do we see some pics/video of it drifting? It can be done on asphalt, wet pavement, or gravel. lol, when its done! and it used to do wet tarmac all the time, but i need an LSD for the dry! lol! Link to comment Share on other sites More sharing options...
backinbrat Posted November 12, 2009 Author Share Posted November 12, 2009 (edited) right, so, update! the heads are back (FINALLY!) from the machine shop, and lookin good! heads on! engine is in! new clutch in behind that as well, and bearing, sitting behind that lightened flywheel, which i can't wait to see how it reasponds! the stainless steel dual port manifolds should be on tomorrow or monday with the webers ontop! plenty left to do still, redo the water lines, new alternator belt,inlet manifolds on, weld on the stainless system, put some new throttle cables in, oil pressure guage to hook up, setup the carbs, test it all etc! Edited November 12, 2009 by backinbrat Link to comment Share on other sites More sharing options...
backinbrat Posted November 12, 2009 Author Share Posted November 12, 2009 Uberoo said: when do we see some pics/video of it drifting? It can be done on asphalt, wet pavement, or gravel. this was with the standard engine in, just a K&N, cherry bomb, RWD and adjusted fuel mixture, loads of other bits and bobs like wheels and lowered etc, but no others engine wise, so eay to kick out in the wet! Link to comment Share on other sites More sharing options...
Phizinza Posted November 13, 2009 Share Posted November 13, 2009 so are you going to run twin spark? Or are those holes just going to be plugged? Link to comment Share on other sites More sharing options...
backinbrat Posted November 13, 2009 Author Share Posted November 13, 2009 i have the twin spark dizzie, but it uses electronic advance, and the gains from it, because of the plug location arnt really justifyable Link to comment Share on other sites More sharing options...
backinbrat Posted November 18, 2009 Author Share Posted November 18, 2009 here are the carbs on the new custom inlet manifolds, made from aluminium Link to comment Share on other sites More sharing options...
rxleone Posted November 19, 2009 Share Posted November 19, 2009 Whoa dude, that is a freakin sweet setup! Get some vids up in the daytime! Link to comment Share on other sites More sharing options...
simple monkey Posted November 19, 2009 Share Posted November 19, 2009 i've never seen a twin carb setup like this on a subie, great build! keep up the good work. Link to comment Share on other sites More sharing options...
Phizinza Posted November 19, 2009 Share Posted November 19, 2009 simple monkey said: i've never seen a twin carb setup like this on a subie, great build! keep up the good work. Google Sub4 and Ram Engines Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted November 19, 2009 Share Posted November 19, 2009 I saw you use the extra spark plug holes and install some NOS injectors Link to comment Share on other sites More sharing options...
simple monkey Posted November 19, 2009 Share Posted November 19, 2009 Phizinza said: Google Sub4 and Ram Engines those are plane engines. i meant "in" a subie. Link to comment Share on other sites More sharing options...
backinbrat Posted November 24, 2009 Author Share Posted November 24, 2009 TheSubaruJunkie said: I saw you use the extra spark plug holes and install some NOS injectors now theres a creative bit of thinkin, i like it! thats gonna get the mind goin now! lol! Link to comment Share on other sites More sharing options...
backinbrat Posted November 24, 2009 Author Share Posted November 24, 2009 well, heres the stainless steel flange plates for the exhaust, 8 in total, and 4 spark plug blank offs for the (atm) redundent plugs Link to comment Share on other sites More sharing options...
sam turner Posted November 24, 2009 Share Posted November 24, 2009 I was thinking of upgrading my stk seats and steering wheel. I saw your pics - is Sparco the way to go - how much work to replace the seats and s. wheel? Sam Link to comment Share on other sites More sharing options...
kiwi subbie Posted November 25, 2009 Share Posted November 25, 2009 backinbrat said: i have the twin spark dizzie, but it uses electronic advance, and the gains from it, because of the plug location arnt really justifyable Gains another 200 RPM lol. Was talking to a guy about the sub4 twin spark heads years ago for aircraft. Thats what he told me what would happen when you switched the 2nd lot of spark plugs on. Link to comment Share on other sites More sharing options...
UK scoob pickup Posted November 26, 2009 Share Posted November 26, 2009 Subarutex said: Why stop at just the rear end? Lets me honest, torsion rear suspensions are ancient. Just as easy you could fab up a 4 link to a solid axle, or even do a subframe swap out of a s13/14/r32. Backinbrat, this could be the best answer if U good at fab/welding. with the flat bed blank piece of paper box section new rails cross pieces to pick up new pick up points subframe.....thinking along these lines as Ive got a bit of rot near torsion bar mounting. As my plans are similar....RWD drift plaything thats able to carry sheets of plasterboard etc..........My thoughts are. gearbox...Imprez/legacy Theese must be able to fit easer than finding alternative?. found a link (must find again) from USMB to another site, guide 2 welding center diff in imp/leg gearbox for RWD. Rear end Impreza/ leg, s13/s14 or go solid. PPC magazine put volvo rear axle in mk2 escort cheep as chips handles loads of power Avalible in open (Welded please) locker or lsd......BMW 3 series? cheep as chips. At the moment I plan to, as mine standard output, weld rear diff (yes eventially it might break transfer shaft in box) but 10min and front shafts from behind seats are back in, limp back home in fwd......by then will have decided best way forward. U got front spoiler thought out yet??? Link to comment Share on other sites More sharing options...
backinbrat Posted November 27, 2009 Author Share Posted November 27, 2009 (edited) UK scoob pickup said: Backinbrat, this could be the best answer if U good at fab/welding. with the flat bed blank piece of paper box section new rails cross pieces to pick up new pick up points subframe.....thinking along these lines as Ive got a bit of rot near torsion bar mounting. As my plans are similar....RWD drift plaything thats able to carry sheets of plasterboard etc..........My thoughts are. gearbox...Imprez/legacy Theese must be able to fit easer than finding alternative?. found a link (must find again) from USMB to another site, guide 2 welding center diff in imp/leg gearbox for RWD. Rear end Impreza/ leg, s13/s14 or go solid. PPC magazine put volvo rear axle in mk2 escort cheep as chips handles loads of power Avalible in open (Welded please) locker or lsd......BMW 3 series? cheep as chips. At the moment I plan to, as mine standard output, weld rear diff (yes eventially it might break transfer shaft in box) but 10min and front shafts from behind seats are back in, limp back home in fwd......by then will have decided best way forward. U got front spoiler thought out yet??? hmm, yes, a 4 link setup would be quite doable i reakon, but i would like to keep independent, the subaru way, if only the LSD's were more avalible over here! ive got some thoughts, and will faff with it when the engine is done, but loads of ideas flying around long of the short, where are you from again, we need to meet up and discuss drifting issues! haha! Edited November 28, 2009 by backinbrat Link to comment Share on other sites More sharing options...
backinbrat Posted November 27, 2009 Author Share Posted November 27, 2009 sam turner said: I was thinking of upgrading my stk seats and steering wheel. I saw your pics - is Sparco the way to go - how much work to replace the seats and s. wheel? Sam personal favourite sparco, i like the style and quality, not that much work to be honest, i got a hub kit for aftermarket steering wheels in a reduced section in a car acccesories shop, was meant for a honda civic, i cut the spline off the old steering wheel, welded it on, and on it all went, horn is on a seperate button, and the seats, i bolted 2 pieces of box section on the front to back of the seats, then going the otherway, welded on with holes to mount the standard runners onto, and they sit bang on where you want them, not too high or low! Link to comment Share on other sites More sharing options...
AlpineRaven Posted January 19, 2010 Share Posted January 19, 2010 How is it coming along? Cheers AP Link to comment Share on other sites More sharing options...
