Land Anchor / Winch Anchor
danrenfroe2016
You could proly fab one of these up for very little if you have a good trustworthy welder.
https://www.expeditionexchange.com/cart/product.php?productid=18555&cat=268&page=3
Ya I have seen that Before, a Fixed, non folding unit could be built fairly easy.
Does a long steel steak beat into the ground work at all?
-Daniel
Edited by danrenfroe2016
Spelling
Does a long steel steak beat into the ground work at all?it could, but the anchor itself needs to have some type of cleats to bite into the dirt harder when you are pulling on it.............
the type you buy , like in the link above, are designed to get more bite,by digging deeper as you pull.this due to the angle of the spade in relation to the ground and direction of pull.so , i imagine alot of ************ will work, just keep the basic design features in mind when you are building it.
-Daniel
cheers, brian
Wow that looks like a simple setup. Looks like it would work good though.
-Daniel
