Engine help
I just bought MY 85 gl hatch and want to restore it best I can.It was the first car I bought and paid for.lots of memories in that car.well I REBUILT THE CARB,hatachi,new plugs wires,disributor,button,both fuel filters,and coil.when the engine warms up to temp the idle will fluctuate between 800-1500.also put new intake gaskets on,pcv valve,and removed and cleaned egr valve.can't locate any more leaks.any help would be appreciated.
Cool, another Virginian.
Are the throttle shaft bores worn? Can you take the throttle shaft and move it back and forth, up and down? If you can, the throttle plates will never be right. Time for a new carb. You can check this by spraying carb cleaner or starting fluid right at the throttle shaft, while wiggling it. It basically causes a big, variable vacuum leak that is hard to track down.
