How to replace front cv axles
It's a 6mm roll-pin. Most of us use 3/16" pin punches to remove them although Snap-On (at least) sells a 6mm roll-pin punch in an extended length version just for Subaru's. The transmission end is the easy part. It's getting them out of the bearings in the knuckle that's the trick. Run a search here on this section of the forum for "axle replacement" - you have some reading to do.
