Pennies Earned Posted October 16, 2009 Share Posted October 16, 2009 I found someone selling a used weber online for a good price. I have an '87 GL Wagon w/ an EA82 motor that is in need of a new carburetor. The seller states that the weber came out of an '85 with a E85 motor. I'm not familiar with an E85 motor and wanted to know if this carb will work on my vehicle. Also, the carb comes with the adapter plate and throttle linkage. Is there anything else I will need? Any particular questions I should ask? Thanks, -Ryan Link to comment Share on other sites More sharing options...
stephenw22 Posted October 16, 2009 Share Posted October 16, 2009 There is no EA-85 motor type. In 1985, it is probably an EA-82, like yours. I'm not as familiar with U.S. models, but they did make Canadian EA-81 models in 1985 as well. I haven't done a weber swap myself, so I can't help you with any of the finer details. Link to comment Share on other sites More sharing options...
Pennies Earned Posted October 16, 2009 Author Share Posted October 16, 2009 (edited) I didn't think that there was such thing as an E85 motor and had told the seller that he might be thinking of an EA82 but he still believes its an E85. I had to come and check here just to make sure I wasn't the crazy one. As far as figuring out if the carb will work or not would it matter what '85 model that he pulled it from? Thanks, -Ryan Edited October 16, 2009 by Pennies Earned Link to comment Share on other sites More sharing options...
GeneralDisorder Posted October 16, 2009 Share Posted October 16, 2009 In '85 it could either be an EA82 (Wagon, sedan), or an EA81 (Brat, Hatchback). Ask him which body style it came from. Even if it's not from an EA82, it will still be jetted correctly and you would only have to buy the adaptor plate for the EA82 manifold ~$35. Beware of used Weber's though. They can be gamble. Make sure the throttle shafts are not worn, and the choke plates aren't sloppy. If you end up having to rebuild/rejet it then you can easily be looking at as much money and more frustration than just buying the kit for $325 or so. I usually expect to spend around $200 to install a used Weber and I've done a LOT of them so I know what I'm doing, what to look for, etc. It's pretty trivial for me to rebuild one, but I usually end up having to buy a couple jets, a rebuild kit, maybe change the choke style, adaptor plate, etc, etc. It's not a cheap proposition. IF the throttle shafts are good, I won't pay more than about $75 to $125 for a used Weber. GD Link to comment Share on other sites More sharing options...
renob123 Posted October 16, 2009 Share Posted October 16, 2009 I didn't think that there was such thing as an E85 motor and had told the seller that he might be thinking of an EA82 but he still believes its an E85. I had to come and check here just to make sure I wasn't the crazy one. As far as figuring out if the carb will work or not would it matter what '85 model that he pulled it from? Thanks, -Ryan Are you sure it came from a Subaru? BMW uses nomenclature like that, I think. Jacob Link to comment Share on other sites More sharing options...
Pennies Earned Posted October 16, 2009 Author Share Posted October 16, 2009 Thanks for the Info. The Weber is a good price ($60) but I haven't looked at it yet. Would it be crazy to assume not to spend any additional money if the carb was in good working condition when pulled? -Ryan Link to comment Share on other sites More sharing options...
GeneralDisorder Posted October 16, 2009 Share Posted October 16, 2009 Crazy.... yes. There will be costs incurred for the install. PCV hoses and adaptors, inline fuel filter (highly reccomended), gasket sealer depending on how you do the adaptor plate. You may have to change idle jets depending on how it runs..... there's always costs associated with Weber installs. You may find something broken or break something yourself durring the process. In addition to the carb and adaptor, you will have to block the ASV's one way or another, as well as reroute/cap a lot of vacuum lines and ports. EGR and distributor advance will need new lines run from the front of the carb, etc. GD Link to comment Share on other sites More sharing options...
edrach Posted October 17, 2009 Share Posted October 17, 2009 Which weber is he talking about? The weber of choice is the DGAV36/32 or the DFAV36/32. They are generally appropriate for 1.5L to 2.0L engines. If they didn't come off a Subaru, then you may have some issues with jetting and such. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted October 17, 2009 Share Posted October 17, 2009 The DGV's are useful for engines upwards of 3 to 3.5 liter's actually. They flow quite a bit more than our tiny little Subaru's need. The DFV with the small venturi's was used stock on many Fords larger than 2 liters. I beleive the Pinto's were 2.4's. GD Link to comment Share on other sites More sharing options...
nolicense Posted October 17, 2009 Share Posted October 17, 2009 i think he was saying it runs off E85. ethanol and not gasoline. if thats the case I dont know what is changed to run e85. Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted June 22, 2013 Share Posted June 22, 2013 (edited) ... The seller states that the weber came out of an '85 with a E85 motor .... Where is Located the Seller? ... In the LADM (Latin American Domestic Market) Subaru Sold certain models, with the EA65 Engine (1.3L) up to 1994; So, if the Seller says it came from a Subaru engine, Maybe he Confused the EA65 with "E85" ... somehow? ~► http://en.wikipedia.org/wiki/Subaru_EA_engine#EA-65 Kind Regards. Edited June 22, 2013 by Loyale 2.7 Turbo Link to comment Share on other sites More sharing options...
