quartus Posted October 20, 2009 Share Posted October 20, 2009 Do you have a 86 GL-10 SW EA82Turbo 5sp 4x4? If so can you send me a photo of the rotor in the distributor (# 22100 AA221) I have the screw on disty cap but I think the rotor I have installed is wrong, seems "short" and just pushes on without a setscrew. Even a part number for the rotor would be great but a photo would be best! Thanks Link to comment Share on other sites More sharing options...
ruparts Posted October 20, 2009 Share Posted October 20, 2009 quartus said: Do you have a 86 GL-10 SW EA82Turbo 5sp 4x4? If so can you send me a photo of the rotor in the distributor (# 22100 AA221) I have the screw on disty cap but I think the rotor I have installed is wrong, seems "short" and just pushes on without a setscrew. Even a part number for the rotor would be great but a photo would be best! Thanks I dont have a picture of one but the hitachi distributor has a cap that is screwed on and the rotor has a hole in the side of it to put a screw into the shaft to hold it in place, that is what your asking right? does your distributor shaft have a small threaded hole in the side near the top. the other type rotor for ND has a flat side and no screw to hold it on. Link to comment Share on other sites More sharing options...
quartus Posted October 20, 2009 Author Share Posted October 20, 2009 Yes, the disty shaft does have the setscrew hole but the installed rotor is a pushon type, the tip of the rotor & the cap contacts seem a long way apart (not quite 1/4"). Do you have a part# for the rotor? Link to comment Share on other sites More sharing options...
ruparts Posted October 20, 2009 Share Posted October 20, 2009 quartus said: Yes, the disty shaft does have the setscrew hole but the installed rotor is a pushon type, the tip of the rotor & the cap contacts seem a long way apart (not quite 1/4"). Do you have a part# for the rotor? hi, they only show 2 different ones for these cars, as far as i know, just get the other one, and of course you will need that little screw. Link to comment Share on other sites More sharing options...
quartus Posted October 20, 2009 Author Share Posted October 20, 2009 Thanks for the help, there is a pre 11/86 and a post 11/86 rotor to choose from, unfortunately I had neither. I had the 85 nonturbo rotor. I found a great place to get parts, http://www.carpartsdiscount.com, it has clear photos of all the different parts. I ordered the right parts today. Link to comment Share on other sites More sharing options...
quartus Posted October 27, 2009 Author Share Posted October 27, 2009 (edited) The right parts make a world of difference, the "old" rotor was shorter. I must of had quite a light show going on inside the disty with a little spark left over for the plugs. Edited October 27, 2009 by quartus Link to comment Share on other sites More sharing options...
