OBD I Tranny into a OBD II Car?!?
I've tried to search the Intraweb, and I found this forum, but I just grenaded my Manual 5spd Tranny in my 2000 Impreza L. 3.90 final yadda yadda yadda.. I found a 95 3.9 transmission for cheap, but it's an OBD I tranny.. Will this work, or will I have to find a OBD II Transmission?
Please OB1, you are my only hope!
I just installed an OBD-I 5 speed into a '96 OBD-II. The biggest difference was the exhaust bracket for the mid-pipe. The bosses on the tranmission for the mount simply didn't exist. I fabed up a mount and welded it to part of the transmission cross-member. The wireing is different but I just swapped the reverse and neutral switches with the one's from the blown tranny. Otherwise it bolted right up. They were both cable clutch's and both 3.9's.
YMMV with a 2000 though.
95 should be an OBDII
nipper
