timfreddo Posted October 21, 2009 Share Posted October 21, 2009 Hi, My 1994 ts-r did something weired the other day, i'll try and explain it to see if you can help. Was adjusting the cigarette lighter socket, partially broken, moves around in the plastic dash peice. Mustv'e been a little heavy handed as a small puff of smoke (possibly dust) came out. Now everything electrical on that part of the dash doesnt work anymore. Air con controls, CD stacker control and cigg lighter aren't working. Radio still works. Do you guys know if one fuse covers all of the above? If so, is it 10, 15 or 20 and could you let me know where its located? The cars a Jap import, so all writing is all in Japanese Is it easy to follow the Haynes Manual in regards to this? just in case its the wiring and not a fuse? Looking forward to your responses. Tim. Quote Link to comment Share on other sites More sharing options...
Rooster2 Posted October 22, 2009 Share Posted October 22, 2009 Sounds like you blew a fuse when adjusting that broken cig lighter. Since I am guessing all fuse box writing is in Japanese, you are prolly better off just pulling each fuse until you find one that is blown. I would recommend doing some dash disassembly to disconnect the wiring to the cig lighter, or you are likely to just keep blowing fuses. Quote Link to comment Share on other sites More sharing options...
