subyfreak Posted October 22, 2009 Share Posted October 22, 2009 I have noticed some oil in the intake box by the throttle body and figure it could be caused by a plugged pcv valve. I have no idea where and how many valves there are on this engine. Any body have a picture of where they are? Thanks in advance. Oh and another thing not related. I need a TPS for a 01 Outback Beener edition if any one knows where I can score a used one. Link to comment Share on other sites More sharing options...
idosubaru Posted October 22, 2009 Share Posted October 22, 2009 drivers side under the washer reservoir on top of the valve cover body. if subaru sent me the right valve, it's smaller than EA/EJ vehicles of the past 20 years. Link to comment Share on other sites More sharing options...
OB99W Posted October 22, 2009 Share Posted October 22, 2009 Ignoring the SeaFoam info, http://www.subaruoutback.org/forums/showthread.php?s=&threadid=14294 describes the PCV valve location and has well-lit pictures as well. Link to comment Share on other sites More sharing options...
Fairtax4me Posted October 22, 2009 Share Posted October 22, 2009 I need a TPS for a 01 Outback Beener edition if any one knows where I can score a used one. What's the part number on the side of the sensor? I may have one taat will work, and if not I can get one for ~ $15. Link to comment Share on other sites More sharing options...
subyfreak Posted October 23, 2009 Author Share Posted October 23, 2009 Thanks everyone for the quick replies. Link to comment Share on other sites More sharing options...
subyfreak Posted October 23, 2009 Author Share Posted October 23, 2009 What's the part number on the side of the sensor? I may have one taat will work, and if not I can get one for ~ $15. Thanks! the wife will be quite happy if you can find one. I will go and check tomorrow for that part number. I will send you a PM when I do. Link to comment Share on other sites More sharing options...
CNY_Dave Posted October 23, 2009 Share Posted October 23, 2009 drivers side under the washer reservoir on top of the valve cover body. if subaru sent me the right valve, it's smaller than EA/EJ vehicles of the past 20 years. NAPA gave me the wrong PCV valve when I tried to change mine, and the wrong one was too small. No idea what it was for, it looked right, was just too small. The stocker is a stout metal unit, and cleaned up fine with carb cleaner. Dave Link to comment Share on other sites More sharing options...
subyfreak Posted October 23, 2009 Author Share Posted October 23, 2009 NAPA gave me the wrong PCV valve when I tried to change mine, and the wrong one was too small. No idea what it was for, it looked right, was just too small. The stocker is a stout metal unit, and cleaned up fine with carb cleaner. Dave Last time I went to the local Napa up here the guys behind the counter tried telling me that my car was only available with the 2.5 and my car had an engine swap done to get the H6 lol. That store has since closed. I will give my pcv a good cleaning before buying a new one. Thanks for the info. Link to comment Share on other sites More sharing options...
CNY_Dave Posted October 23, 2009 Share Posted October 23, 2009 Come to think of it, an H4 PCV valve will have the guts reversed from an H6. H4- threaded end to vacuum, H6- hose end to vacuum. Dave Link to comment Share on other sites More sharing options...
