pirata_manu Posted October 25, 2009 Share Posted October 25, 2009 I have a 96 legacy outback wagon. rotational bearings (rod or main) are likely fouled thus I think an engine replacement is in order. I understand that low mileage (20 - 50K) used engines are available in the western USA from japan really cheap. does anyone know where I might order a 1996 2.5 liter or comperable motor? does anyone have a link to a motor exchange Biz? I am stranded on I80 in Nevada. I want a motor cheap and fast. please help. Link to comment Share on other sites More sharing options...
lmdew Posted October 25, 2009 Share Posted October 25, 2009 How close are you to Salt Lake City? There are 3 good you pull and pay yards in town. Drop in a good 95 2.2 from an auto so it has the EGR. www.car-part.com is a good yard search or junkyarddog.com Link to comment Share on other sites More sharing options...
johnceggleston Posted October 25, 2009 Share Posted October 25, 2009 (edited) I have a 96 legacy outback wagon. rotational bearings (rod or main) are likely fouled thus I think an engine replacement is in order. I understand that low mileage (20 - 50K) used engines are available in the western USA from japan really cheap.does anyone know where I might order a 1996 2.5 liter or comperable motor? does anyone have a link to a motor exchange Biz? I am stranded on I80 in Nevada. I want a motor cheap and fast. please help. ok, you are new and you are desperate. i do not see cheap in this outcome. some basics. any 2.5L engine 96 - 99 from a legacy (outback, GT, LSi) will work. but you might just be buying someone else's bad head gasket engine.. beware. any 2.2L engine, 90 - 99 will work, but some will be easier / better than others. a 95 2.2L engine from an auto trans car is your first choice, it has the EGR system you need. a 96 2.2L engine will be second, but you will also need the exhaust manifold y-pipe, (one has single exhaust port heads and one has double exhaust port heads). 97 - 99 will be an easy swap, but some may not have the EGR, double check. a 90 - 94 will bolt in and run just fine, but none of them have the EGR and so you will always have a CEL light. you can search here: www.car-part.com . or you can contact www.CCR.com. (i think that is the address, if not you can put this phrase into the search engine here and find them : "CCR*". or google colorado rebuilders maybe. they have replacement, completely rebuilt engines with warrantys which they will stand behind. now, why do you need a new engine????? Edited October 25, 2009 by johnceggleston Link to comment Share on other sites More sharing options...
