SubaruJawn Posted October 25, 2009 Share Posted October 25, 2009 Hey All Well Since got another Road Legal Subaru time to start another Thread. just like Scubert's anything wrong that i need help with will be posted Here. Now i do need help with: Driver side Power Window. it doesn't work up or down (currently up) Passenger Mirror (both didn't blown fuse changed it and now only passenger) Hood Latch any ideas on how to fix ? Specs: 1990 Subaru Legacy L Fulltime 4WD 5 Speed Manual 2.2L 16 Valve H4 185/70 R14's 202,649 Miles When i got it Pictures of My Legacy: BEFORE: PROGRESS: Now: Painted Grill,Cleaned off Hood & Washed The car Removed Stickers Clean Up Interior Alittle Dash Miles Added Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted October 26, 2009 Share Posted October 26, 2009 Nice Legacy! With the Power Windows` Switch, I Kindly Suggest you to Try with Another Switch from a Junk Yard... Usually Rust on internal Switch`s Parts lead `em to Fail and Repaired Switches Won`t Last too Much... Kind Regards. Link to comment Share on other sites More sharing options...
SubaruJawn Posted October 26, 2009 Author Share Posted October 26, 2009 the car had of been hit in such a way that caused the top mount were radiator bolts to bend back. since that's were the hood latch mounts it causes prevention of the hood latching. i bend it forward and when hood comes down just pushes the latch back preventing it from latching with the hood. i managed to make it stay and the hood did latch. now how to make a permanent way to prevent that bar from bending back again:confused: Link to comment Share on other sites More sharing options...
SubaruJawn Posted October 30, 2009 Author Share Posted October 30, 2009 New Sticker. Pass PA's Strict Inspection Changed the Fenders. of my old 91 Legacy i stripped Link to comment Share on other sites More sharing options...
SubaruJawn Posted November 2, 2009 Author Share Posted November 2, 2009 Update: fixed backup light Tarred Underside (typical areas only) Put XT6 Rims on Pictures: changed the air box: to Cotton Cone Filter: Problems to fix yet: Drivers Door doesn't shut Properly (don't have a Fing Clue how to fix) Drivers Side Window (believe its the motor after some tests) Link to comment Share on other sites More sharing options...
SubaruJawn Posted November 7, 2009 Author Share Posted November 7, 2009 Update: Oil Coating Painted Grill Primed Fenders Painted Fenders End Result: Link to comment Share on other sites More sharing options...
SubaruJawn Posted November 10, 2009 Author Share Posted November 10, 2009 Are These The Original Factory Wires ? Yazaki 1989 R-16-AIPS the car has over 203,000 Miles -John Link to comment Share on other sites More sharing options...
SubaruJawn Posted November 13, 2009 Author Share Posted November 13, 2009 After a Cleaning, Waxing and Change of Rims. here is what my Legacy Looks Like now. Parked down at the Fire Hall. just like i did Scubert Xt 8) Link to comment Share on other sites More sharing options...
SubaruJawn Posted November 19, 2009 Author Share Posted November 19, 2009 (edited) drivers side window does not work. and believe its the motor. so would an XT6 Motor work ? what about a Loyale motor ? i would like to get the drivers side window fixed. John Edited November 20, 2009 by SubaruJawn Link to comment Share on other sites More sharing options...
B.Boognish Posted November 20, 2009 Share Posted November 20, 2009 No, neither of those other motors will work. Did you check for voltage at the motor with a test light or a multimeter when you operate the switch? Link to comment Share on other sites More sharing options...
SubaruJawn Posted November 25, 2009 Author Share Posted November 25, 2009 B.Boognish said: No, neither of those other motors will work. Did you check for voltage at the motor with a test light or a multimeter when you operate the switch? dunno how to do that. would a 95 Legacy Motor work in a 90 Legacy ? Link to comment Share on other sites More sharing options...
Gloyale Posted November 25, 2009 Share Posted November 25, 2009 Subex said: dunno how to do that. would a 95 Legacy Motor work in a 90 Legacy ? Yes, but if you don't even know how to use a flipping test light what are you even trying for? Try reading some basic testing and repair manuals before you start wasting our time asking irrelevant questions. If you don't know wether or not voltage is getting to the motor, how can you diagnos it as bad? Heck just run 2 wires to the motor and put 12v on it. Try it both ways, wires one way is up, the other is down. if the motor doesn't respond to direct voltage, THEN it can be deemed bad. Link to comment Share on other sites More sharing options...
SubaruJawn Posted November 25, 2009 Author Share Posted November 25, 2009 Gloyale said: Heck just run 2 wires to the motor and put 12v on it. Try it both ways, wires one way is up, the other is down. if the motor doesn't respond to direct voltage, THEN it can be deemed bad. did that. motor moved slightly. then didn't move again in neither up or down and excuse me for not knowing how to use a test thing... i never learned to use one. Link to comment Share on other sites More sharing options...
torxxx Posted November 26, 2009 Share Posted November 26, 2009 you never learned how to use a test light? come on dude, its common sense.. you clip the alligator clip to a ground and stab a positive wire with the end of the probe.... if its getting power the handle of the probe lights up.. I find it hard to believe that someone who is capable of changing a fender, doesnt know how to use a test light Link to comment Share on other sites More sharing options...
SubaruJawn Posted November 26, 2009 Author Share Posted November 26, 2009 torxxx said: you never learned how to use a test light? come on dude, its common sense.. you clip the alligator clip to a ground and stab a positive wire with the end of the probe.... if its getting power the handle of the probe lights up.. I find it hard to believe that someone who is capable of changing a fender, doesnt know how to use a test light test light....i was thinking of that yellow thing with a dial and 2 probes. to come think of it i'm not sure we have one. and i didnt think of using one either. Link to comment Share on other sites More sharing options...
SubaruJawn Posted December 20, 2009 Author Share Posted December 20, 2009 Update: a local yard called Seaman's Auto Wrecking has outback struts and for only $10ea if i pull them. as soon as i get the money i'll go buy all 4 and put them on my legacy Link to comment Share on other sites More sharing options...
AWDfreak Posted December 21, 2009 Share Posted December 21, 2009 Subex said: Update: a local yard called Seaman's Auto Wrecking has outback struts and for only $10ea if i pull them. as soon as i get the money i'll go buy all 4 and put them on my legacy Nice to know you're getting those Outback struts! When you get them installed, tell us how much higher it is! I'd like to know if the ground clearance exceeds that of my Outback (which has a listed ground clearance of 7.3 inches). Link to comment Share on other sites More sharing options...
SubaruJawn Posted January 11, 2010 Author Share Posted January 11, 2010 ok so i finally got the money for the Outback Struts:). Correct me if I'm wrong. Outback Struts with my Legacy's Stock springs to get maximum Strut lift. also thought about L.S.D now what models had these ? Turbo did dint they ? i know were 1 92-94 Legacy Turbo wagon sits. I'm thinking its a 3.90 Gear Ratio ? while my non Turbo is 4.111 is the turbo 3.90? or a 4.11 ? Thanks for any useful Info -John Link to comment Share on other sites More sharing options...
SubaruJawn Posted March 1, 2010 Author Share Posted March 1, 2010 Update: Hood Work: I Really Love this Legacy. its Da Bomb ! plenty more to do Link to comment Share on other sites More sharing options...
Olnick Posted March 1, 2010 Share Posted March 1, 2010 Good going, John. Nice job on the hood & paint--you're going to have it looking like a new car soon! Keep showing us the progress. Link to comment Share on other sites More sharing options...
SubaruJawn Posted March 1, 2010 Author Share Posted March 1, 2010 Olnick said: Good going, John. Nice job on the hood & paint--you're going to have it looking like a new car soon! Keep showing us the progress. better than new and yes will keep up to date Link to comment Share on other sites More sharing options...
SubaruJawn Posted March 4, 2010 Author Share Posted March 4, 2010 Changed the Grill. this was off my old gray one. as sum of you guys know which one. Painted it red and painted center black: Did some Touch up: Link to comment Share on other sites More sharing options...
AWDfreak Posted March 5, 2010 Share Posted March 5, 2010 (edited) Subex said: Changed the Grill.this was off my old gray one. as sum of you guys know which one. Painted it red and painted center black: Did some Touch up: OMFG!!! Awesome!!! Looks very clean. Now it needs some mud I need to fix some things on meh Outback too... Edited March 5, 2010 by AWDfreak Link to comment Share on other sites More sharing options...
gfrg88 Posted March 5, 2010 Share Posted March 5, 2010 Looking good!! Are you using just spray cans for the paint??? keep up the good work Link to comment Share on other sites More sharing options...
SubaruJawn Posted March 5, 2010 Author Share Posted March 5, 2010 gfrg88 said: Looking good!! Are you using just spray cans for the paint??? keep up the good work for the window trim I'm using spray can. as for the body of the car. I'm using actual spray gun and auto paint. Link to comment Share on other sites More sharing options...
