ScubyLegz - 1990 Subaru Legacy L
Did you figure out the power window problem? Looks like you're pretty handy with a paint gun and spray can!
i got the window working yes. but now its out of alignment. yet to fix.
and thanks i have used spray cans alot in my younger days. spray gun i'm new at. couldnt do it with out my fathers guidance.
Nice videos, good music selections. I really enjoyed!
Quick question--how did you prep the gutterstrip trim over the windows for painting? Did you scrape off all the old black plastic covering first then sand the "chrome" base?
I Just made sure it was clean sprayed it.
the passenger side is not as great.
sadly these are only temporary.
the rims & 2 Tires belong to my father. 2 tires belong to me (rear ones)
its still not big enough. and the rear wheels now only have like 1cm space from the dog leg
my tires are also very close to the end of the rocker but never rub because when your hitting bumps the tire will move tward the rear, not closer to the rocker
  • 2 months later...
  • 1 year later...
Are These The Original Factory Wires ?
Yazaki 1989 R-16-AIPS
the car has over 203,000 Miles
-John
Did you ever found out if these were the factory wires? I just pulled a set of these off my car with 283,000 miles. Found a small whole in them that was causing problems. This Yazaki wires sure fit better than the BWD wires I got to replace them.
