()__1337_CRAYOLA__()> Posted October 26, 2009 Share Posted October 26, 2009 (edited) Ok i have a 1983 Wagon with fuel injection swap. I've been having trouble with the car since i got it, it wont hold speed up hills and just down on power, but today i go out to fire it up and it shows no sign of life just turning over no sputtering or anything. So i add some throttle to see if it will come to life and it fires up and the engine light comes on and at this point it is running like poo. so i pull the kick panel down and plug the green connectors in to check codes and it shows a code of 5. now that would be fine and dandy but i cant find anywhere for a problem related to 5 flashes. (yes it is 5 short consecutive flashes then a long pause then it does it over again) so WTF.... I'm about to rip all the FI stuff of and throw it away for a weber.... (also i don't know if it matters tho i don't know the year of the FI swap either...) Edited November 1, 2009 by ()__1337_CRAYOLA__()> Link to comment Share on other sites More sharing options...
GeneralDisorder Posted October 26, 2009 Share Posted October 26, 2009 5 is a model code that indicates no fault. It just tells what the transmission type was of the car the ECU came from, etc. GD Link to comment Share on other sites More sharing options...
()__1337_CRAYOLA__()> Posted October 26, 2009 Author Share Posted October 26, 2009 so what the heck is wrong with my car if it threw a light but doesn't show a code.... new fuel filters and just cleaned the MAF.... i give up on this fuel injected stuff haha... Link to comment Share on other sites More sharing options...
Gloyale Posted October 26, 2009 Share Posted October 26, 2009 Green connectors are for running a "self test" so to speak. It won't output codes tripped in the past. Use the 2 white (or balck) connectors for reading past codes. plug in both sets to clear memory. Remember, you need to idle the engine above 2000 rpm for about 40 seconds, and drive over 1 MPH to fully cycle the ECU through the code process. Or else you will get false codes for VSS and possibly Idle switch and others. Link to comment Share on other sites More sharing options...
()__1337_CRAYOLA__()> Posted November 1, 2009 Author Share Posted November 1, 2009 well it runs like a champ now! i open up the cat cause my bro said it has to be clogged and i found that all the catalyst was gone and this was clogged hard in to the exit of the cat hahahaha Lesson learned the vacuum check for clogged cats does not work.... Link to comment Share on other sites More sharing options...
()__1337_CRAYOLA__()> Posted November 2, 2009 Author Share Posted November 2, 2009 Resonator was full of crap as well today when i cut it out to check it so i replaced it with a Cherry Bomb Link to comment Share on other sites More sharing options...
