s1l3ntr4ge Posted October 27, 2009 Share Posted October 27, 2009 If i drill the Ea81 flywheel out so it is the same size as the EA82 it will mount up fine.. but will it work well or cause problems down the line? has any one done this and with what result. thanks bryce ps. will this work with an EA82 5sp d/r tranny Link to comment Share on other sites More sharing options...
GeneralDisorder Posted October 28, 2009 Share Posted October 28, 2009 Only some of the EA82 D/R clutch disc's will fit the EA81 pressure plate. If you find one that does then the EA81 flywheel/pressure plate will work no problem. I can't for the life of me figure out why you would want to do such a thing though. Seems totally silly. GD Link to comment Share on other sites More sharing options...
s1l3ntr4ge Posted October 28, 2009 Author Share Posted October 28, 2009 Only some of the EA82 D/R clutch disc's will fit the EA81 pressure plate. If you find one that does then the EA81 flywheel/pressure plate will work no problem. I can't for the life of me figure out why you would want to do such a thing though. Seems totally silly. GD LACK OF FUNDS and i have an ea81 flywheel so yeah Link to comment Share on other sites More sharing options...
GeneralDisorder Posted October 28, 2009 Share Posted October 28, 2009 Go get a used EA82 flywheel from the junk yard. Typically about $10 - $15. $35 to have it resurfaced if it needs it. Cheaper than new anyway. Using an EA81 setup in an EA82 like that is just asking for trouble later. The EA81 pressure plate doesn't match up to the EA82 release bearing, and very few EA82 disc's will fit inside the EA81 pressure plate. Only the one's with small, round shaped spring dampeners will fit and those aren't that common in my experience. GD Link to comment Share on other sites More sharing options...
s1l3ntr4ge Posted October 29, 2009 Author Share Posted October 29, 2009 where are there subaru graveyards cause this side of the river i cant find a yard with any subarus.... Link to comment Share on other sites More sharing options...
GeneralDisorder Posted October 29, 2009 Share Posted October 29, 2009 Go to the Portland yards. You are close enough and there's no sales tax here. Any of the LKQ self-service yards will have dozens of EA82's. GD Link to comment Share on other sites More sharing options...
s1l3ntr4ge Posted October 30, 2009 Author Share Posted October 30, 2009 sweet thanks Link to comment Share on other sites More sharing options...
