October 29, 200916 yr I need to winterize my Subie with fresh antifreeze. Do I pull the top or bottom hose to the radiator to drain out the old antifreeze. I know in the past, I have used a garden hose to flush water through the system. Just can't remember which hose to pull. Thanks for advise.
October 29, 200916 yr I always yank the bottom hose and thermostat on my 90 lego. And I open the radiator cap after I get the hose off, so as to not get too soaked by the outgoing fluid. It seems the best way to empty the cooling system. And I use the garden hose to flush it as well. Twitch
October 29, 200916 yr Why not just use the drain in the radiator. You do use deionized water afet the garden hose flush or a 50/50 premix i hope. Coolant only really needs to be replaced every 3/36K nipper
October 29, 200916 yr Author Thanks for the advise. It has been 3 years since antifreeze has been replaced. I will change thermostat as well. I will put the car up on ramps on the front. I hope raising the front end causes a good burp to rid any air in the cooling system.
October 29, 200916 yr Thanks for the advise. It has been 3 years since antifreeze has been replaced. I will change thermostat as well. I will put the car up on ramps on the front. I hope raising the front end causes a good burp to rid any air in the cooling system. Key to avoiding air is simple (ramps arent needed but it helps). Always have the car running when you add coolant. Pour in the coolant SLOWLY. STop when full, wait for the thermostat to open, then SLOWLY add more. Put the cap back on, close the bleeder, drive around the block, let car cool off. Repeat if needed. And always watch the temp gauge when doing this. People get air in the system cause they rush this part (any car can get air, some more prone then others). nipper
October 30, 200916 yr Author You do use deionized water afet the garden hose flush or a 50/50 premix i hope. What is deionized water? That is a new one one me..........Rooster2
October 30, 200916 yr You do use deionized water afet the garden hose flush or a 50/50 premix i hope. What is deionized water? That is a new one one me..........Rooster2 After the flush. Sheesh deionized water has been around as long as there have been steam irons. It's just demineralized water. Use the 50/50 premix. nipper
October 30, 200916 yr Distilled water is the term. when you go to the store, they have bottle of "drinking' water and then there will be bottles of "distilled" water. Its the distilled that you want for mixing with antifreeze. clear? Or, if you are cheap like me, and you run a dehumidifier to remove moisture in the home, the water which is pulled into the dehumidifier will also be the same as distilled. I dont know why anyone buys premixed antifreeze Price wise, a gallon of antifreeze that is straight antifreeze, non mixed, is priced exactly the same as the gallon of premixed. so, for an extra 79Cents (cost of a gallon of distilled water) you get double the antifreeze that is usable for only a few cents extra. Edited October 30, 200916 yr by bheinen74
October 30, 200916 yr Author Distilled water is the term. when you go to the store, they have bottle of "drinking' water and then there will be bottles of "distilled" water. Its the distilled that you want for mixing with antifreeze. clear? Or, if you are cheap like me, and you run a dehumidifier to remove moisture in the home, the water which is pulled into the dehumidifier will also be the same as distilled. I dont know why anyone buys premixed antifreeze Price wise, a gallon of antifreeze that is straight antifreeze, non mixed, is priced exactly the same as the gallon of premixed. so, for an extra 79Cents (cost of a gallon of distilled water) you get double the antifreeze that is usable for only a few cents extra. Okay learned deionized is same as distilled. I keep a gallon around to add to car batteries when needed. I will put it to good use.
October 30, 200916 yr Okay learned deionized is same as distilled. I keep a gallon around to add to car batteries when needed. I will put it to good use. I guess it is like soda vs pop. nipper
October 30, 200916 yr Author I guess it is like soda vs pop. nipper yep, good analogy............soda vs pop!
