mjcee Posted October 30, 2009 Share Posted October 30, 2009 I saw you talking about EPMI axles in a previous thread. And I think I read that the turbo and non turbo axles were a bit different. I found this place that carries EPMI's. http://www.car-stuff.com/store/?N=11749+4294963403+1719+11921+5637 I need fronts (both sides). Can you point me to the right ones? It's an 86 Turbo, Fuel Injected, Manual Trans (if that matters). I want to make sure I don't f up and order the wrong ones. Thanks. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted October 30, 2009 Share Posted October 30, 2009 When you search that site, bring up the parts listing for an '86 RX (or any year RX for that matter), and select the axle that says "25 Spline I.B." Looks like they are $85. Not bad although my local dealer in EMPI axles is cheaper by a little bit. Last set of EA82's I bought were $65 each. They list them for $80 so about $15 more per. You might check around your area for an EMPI dealer (places that specialize in air-cooled VW's are a good place to start - that's where I get mine). GD Link to comment Share on other sites More sharing options...
mjcee Posted October 30, 2009 Author Share Posted October 30, 2009 When you search that site, bring up the parts listing for an '86 RX (or any year RX for that matter), and select the axle that says "25 Spline I.B." Looks like they are $85. Not bad although my local dealer in EMPI axles is cheaper by a little bit. Last set of EA82's I bought were $65 each. They list them for $80 so about $15 more per. You might check around your area for an EMPI dealer (places that specialize in air-cooled VW's are a good place to start - that's where I get mine). GD nice! thanks. Link to comment Share on other sites More sharing options...
