i have a 2000 legacy outback wagon- with 4.11 5spd trans. it took a superpoop
i need to know what other transmissions i can put in, obviously must me another 411 5spd- but
for example, a 99 forester 411 5spd- direct swap? im aware that they have different 1st05th gear ratios,i could care less- as long as it bolts in, throws no codes, and i dont need to modify axles or drivelines.
please help asap- my car is down and i have small subie enthusiests that need to go to school
Subaru 5 speed transmissions pretty much interchange over a fairly wide spread of model years. Just watch the rear diff ratio and whether it's a cable or hydraulic clutch (although even that can sometimes be converted). Check out the USRM for transmissions that would suit you. A Forester transmission would probably work just fine for you. Lastly, try to match up engine types (e.g. I wouldn't install a EJ18 transmission in your Outback even if it might fit). Edited by edrach
match gear ratios and clutch type and swap all day.
i've heard people say you can interchange clutch/cable style trans but you'd have to deal with swapping all the linkages, cables, pedal stuffs, etc. and i haven't actually seen it done/confirmed.
I currently have a former WRX ('95 JDM version) transmission in my Impreza. Needed to convert a hydraulic to a cable type. Needed to change the clutch fork, move the pivot ball, remove the hydraulic stuff and install. Works great!
It sounds like this might be answered? as such, i have a similar but different concept question.
What do people think about swapping an Aussie Forester (say 98-00?) 5MT into a USDM 95 Legacy? What issues concerns might i need to think about and look into more deeply? As I understand the AU FOR is 4.11, so i'll need a 4.11 rear diff, but otherwise will there be other concerns if FOR is 2.5 and my Leg is 2.2? If there are different bolting (bell housing) paterns, say FOR is 6 bolt but my Leg is 4 bot, would they still mesh where they overlap??
Thoughts continue, but looking for more heads' worth of Suby experience, and ideas I wouldn't think to concern myself with.
Thanks!
-mark-
Edited by superu
4.22 corrected to 4.11 per edrach
  • 2 weeks later...
What do people think about swapping an Aussie Forester (say 98-00?) 5MT into a USA 95 Legacy? What issues concerns might i need to think about and look into more deeply? As I understand the AU FOR is 4.11, so i'll need a 4.11 rear diff, but otherwise will there be other concerns if FOR is 2.5 and my Leg is 2.2? If there are different bolting (bell housing) patterns, say FOR is 6 bolt but my Leg is 4 bot, would they still mesh where they overlap??
I have a cable (push?) clutch. Are AU FOR clutches cable (push?) or hydraulic (pull?)?
Thanks!
-mark-
bump
