91 Legacy, possible worn out AC-compressor- Can I disable it?
Hi there
About a week ago I smelt something sort of burning/electrical/rubber. Since that time I have heard a new "whine" in the engine, that goes up and down with the accellerator, but lags just a bit.
After poking my head around under the hood, I >suspect< that it is the AC compressor. I don't really use AC that much ,and was wondering if it is easier to just disable it (ie, remove the belt), than replace it (ie = $$).
Do I need to worry about the decreased load on the system? Seems like that could be a >good< thing.
Thanks -Nick
To disable it disconnect the compressor clutch wire. It should have a connector that can easily be unplugged. I would wrap both connectors with electrical tape or something to keep them clean. Make sure you tie them out of the way so they dont cause a problem.
