Announcements
EA82T into a EA82 loyale?
  • Replies 59
  • Created
  • Last Reply
Top Posters In This Topic
Just get a used one - you absolutely sure it's the fan motor? Might be the thermo-switch. Have your dad put 12v to the fan and see if it turns. They rarely fail.
The "blower motor" is the fan for the HVAC system in the cabin. The fan for the radiator is a "Cooling system fan", or "Radiator fan".
The Fel-Pro kit is full of crappy gaskets - especially the intake and exhaust. You DO NOT want to use the Fel-Pro intake gaskets as they seal the coolant ports on the heads. The Fel-Pro one's are just cardboard and they suck. The OEM gaskets are neoprene over metal. Big difference in quality. As I said - Fel-Pro ONLY for the head gaskets. You don't want the rest of their garbage. Been there, done that.
For the extra $50 it's going to cost you, you WANT the stuff from the dealer. Trust me on this one.
I'll have him try that.
On another note: Maybe we can get a mod. to edit this thread, and I'll make the official EA82 headgasket/DIY out of it. I'll make up a parts list for the headgasket, and a "what to get" (brand wise). and I'll get my dad to send over some pictures in the process, and maybe we can help some others out in the future.
What parts do you recommend for the re-seal?
I listed all the parts you need for the reseal in my previous list above.
As for the valve covers.... I don't replace them unless they are cooked and brittle. I carefully remove them, apply RTV to the groove they sit in, put them back into the valve cover and then apply RTV to the outside of the gasket. I also apply RTV to the inside and outside of each bolt grommet. Saves me money and lasts longer than a new set of valve cover gaskets. If I were buying them I would get them from the dealer - they don't last very long as it is - I can't imagine what chinese one's would be like :-\
