Loyale 2.7 Turbo Posted August 9, 2015 Author Share Posted August 9, 2015 (edited) "Made in Honduras" Kia Parts Long time ago, I obtained this thick mudflaps for the rear of the "KiaStein"... Those are made locally! ... For the Front Wheels I obtained Generic Rubber Mud Flaps: To install them, I just unbolted the Plastic Screws that the car has there,and obtained millimetric Metallic ones on same size, thread and pitch,I opened the Holes on the Generic Mud Flaps and used metallic Wahers: This is How the "KiaStein" looks like with those Mud Flaps: Kind Regards. Edited August 10, 2015 by Loyale 2.7 Turbo 2 Link to comment Share on other sites More sharing options...
playabarz187 Posted August 10, 2015 Share Posted August 10, 2015 Awesome job/write ups. You are a true mechanic. Here in the states most people would have just thrown on new parts for everything (including subpar new parts) but you stay true to being resourceful, smart, and getting the job done in the best way. 1 Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted August 10, 2015 Author Share Posted August 10, 2015 On 8/10/2015 at 12:57 AM, playabarz187 said: Awesome job / write ups. You are a true mechanic... Thank you for your Kind Words which I Really Appreciate. Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted August 10, 2015 Author Share Posted August 10, 2015 Now I am thinking about replacing the under bumper Halogens on the "KiaStein" with something better, more efficient; however I refuse to install H.I.D. lights on Headlamps with Plastic lenses; I install H.I.D. on Glass Headlamps only to avoid Dangerous Glare from yellowish / non completely transparent plastics. Despite that the Headlamps are more than enough for City driving, the reason is that they're insufficient for the many nocturnal travels on secondary / two way roads; plenty of potholes, potholes inside the potholes, animals crossing, and even worse: Animals Driving! In the past, people were Worried about H.I.D. lights retrofitted in many old cars, however, the problem nowadays is those High intensity LED bars, installed in many, many cars, providing an horrible Glare, which blinds the incoming driver ... the Regular High Beams on the Headlamps aren't enough to illuminate the road in front, against that blinding light barrier, and we need something that could let us see further, preferably without blinding the incoming traffic. I am accustomed to my Subaru's 5000K H.I.D.'s with tremendous 55W per headlamp, those have High and Low beams, and I installed them on Glass Headlamps, but I refuse to retrofit same / similar system on the Plastic headlamps of this Kia. Bigger Halogens for the under bumper area will not fit, because the small space given there... so what could you Suggest? Are there any non-blinding small LED lights that I could install on the under bumper area of this Kia? Or maybe small, self-ballasted H.I.D.'s? Any suggestion will be welcome ... Kind Regards. Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted August 28, 2015 Author Share Posted August 28, 2015 (edited) I found a torn inner rubber boot on the Passenger's side axle, I thought that there was something wrong with the design on that area, because the rubber boot passes extremely Close to the oil pan and even it rubs against it, and the extra Heat shorten its lifespan... However, I decided to remove both sides' Axles from the "KiaStein" and clean them, regrease them, place new Rubber Boots, and clamps, and finally, reinstall them. Edited August 18, 2016 by Loyale 2.7 Turbo Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted August 28, 2015 Author Share Posted August 28, 2015 (edited) The Rubber Boot that I was using, for the inner side of the C. V. Joint, was Wrong. I was using a Thick one that rubbed against the Engine's oil pan. I searched for the Proper inner rubber Boot.You can read the Complete information and see Photos, Here:~► CLICK HERE!The "KiaStein" continues to perform Flawlessly, thanks to God.Kind Regards. Edited November 16, 2016 by Loyale 2.7 Turbo Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted September 16, 2015 Author Share Posted September 16, 2015 From the beginning, I've been pouring good quality 15W~40 motor oil on the T8D engine of the "KiaStein" because it is the maximum thickness that the Kia Factory indicates, to be used on warm climates... ...so, since we live in the Caribbean, that has been the oil used;in Motul brand, either 15W~40 or 10W~40:Also I used Motul on my Subaru "BumbleBeast" but in 20W~50 However, suddenly I noticed that both cars started to have an abnormal oil consumption, I asked to my friend who has a repair garage and sells the Motul oils, and he admitted that the same was happening with all his clients that were using Motul; something might happened to their oil refinement at the factory... but whatever reason it was, I had to switch from the 20W~50 Motul used on my Subaru, and also I switched our "KiaStein" to Chevron's "Delo 400" motor oil, suitable for Gasoline and Diesel engines, according to the American Petroleum institute's round seal on the Back: Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted September 16, 2015 Author Share Posted September 16, 2015 First, I tried on the "KiaStein" this also European motor oil, from Liqui-Moly; which has the MOS2 additive: Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted September 16, 2015 Author Share Posted September 16, 2015 Liqui-Moly is Awesome, but pretty expensive. Besides that, at the same time I switched my Subaru "BumbleBeast" to another brand, and I chose Valvoline's 20W~50 motor oil for Higher Mileage engines, known as "Max Life" which was providing Awesome results on my Subie; such as much quieter and noticeably smoother engine operation. So I tried that same "Max Life" motor oil on our "KiaStein" but in 10W~40 grade: Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted September 16, 2015 Author Share Posted September 16, 2015 Also I'm using "Max Life" on the Power Steering fluid of both cars, and "Max Life" ATF on the Automatic Transmission of the "KiaStein" as you can see in previous posts of this thread, always with Awesome Results.Kind Regards. Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted September 16, 2015 Author Share Posted September 16, 2015 Something that is Great on this "KiaStein" is the Suspension, it has 16 years old and besides that the coil springs are a little worn, the four shock absorbers are absolutely Healthy, also the rest of the parts involved, which is unbelievable for a car that was very mistreated by the previous owner, and is suffering from constant Pot holes on our Honduran roads; it is pretty well for being 180K miles...Kind Regards. Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted October 15, 2015 Author Share Posted October 15, 2015 I did some home repairs for a Guy who offered to pay me with a couple of small LED lamps, one for each corner of the Bumper, I thought it was good idea to swap the Halogens with Leds, so, I worked changing a toilet, repairing some piping fixtures, and some roof lamps... But the guy gave me this, instead the two small ones: He told me that he thought he had a pair, but that is a single one with 24 LED's ... and I really don't like it; the light pattern can Not be adjusted properly and those provides too much Glare that blinds incoming traffic, which is Dangerous... in the end I had to take that lamp with me, and now I am trying to sell it among the people I know...So, no illumination improvements yet ... ... Kind Regards. Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted October 15, 2015 Author Share Posted October 15, 2015 So, I took the Family to another weekend trip, to a small Mountain Village, The full story and photos are ~► Here, but lI'll share some on this post. I was at a Hilltop when I spotted this... ...first gen Kia Sephia (a Korean Ford Escort), I used my Camera's Zoom to see its Enormous... ...LED light bars ... ... so, I walked down to take a Closer photo, see: I remember people were complaining about the Glare, from HID lights Retrofitted on Halogen Headlamps... ...this must be even Worse. I refuse to install LED bars on my Cars. Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted October 15, 2015 Author Share Posted October 15, 2015 Suddenly, the Driver's door Handle, broke and I couldn't open the Door from the outside anymore; so I decided to remove the door Handle and see what happened: The plastic piece that moves along the Handle, to pull the metal rod that opens the Door, was fissured, broken in two; so I grabbed my twenty years old Ryobi drill, and using a ⅛" bit, I drilled a vertical hole that went down along the broken part: I already had fixed the loose spring's Hookup, long ago... Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted October 15, 2015 Author Share Posted October 15, 2015 After drilling the hole, I slowly inserted a ⅛" Ø X 1½" long, self tapping Screw, with the aim of joining the two parts of the Plastic piece, back together: Finally, I filled all the openings on said Plastic part, with 4 minutes JB Weld glue, to make it Solid and Stronger; because the part came with certain empty spots: Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted October 15, 2015 Author Share Posted October 15, 2015 The Repaired door Handle, already have two weeks working Absolutely Flawlessly, and according my Wife, the handle needs much less movement to open the door, than before.This repair was super fast and easy; I hope this ideas will be useful for other car's owners. Sometimes you don't need to buy another part to fix a problem with your car...Kind Regards. Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted October 16, 2015 Author Share Posted October 16, 2015 My 24 LED Bar is Blinding for sure, I don't like to have such kind of Glare for the incoming drivers, it would be disrespectful for them, and dangerous for everyone on the road as well. I was hoping to obtain a pair of small LED lights to substitute the under bumper Halogens, to be used along the High Beams during night travels, as we use the Halogens; so they turns off when we switch to Low Beams. What I've changed recently, were the Tail light's Sockets for the single-contact 1156 bulbs; those were made from plastics that crumble with age, so I obtained the Best sockets I could, locally, those are Flösser, made in Germany: Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted October 16, 2015 Author Share Posted October 16, 2015 (edited) On 8/10/2015 at 5:59 PM, Loyale 2.7 Turbo said: ... I am accustomed to my Subaru's 5000K H.I.D.'s with tremendous 55W per headlamp, those have High and Low beams, and I installed them on Glass Headlamps ... More information on the Subject, here: ~► http://www.ultimatesubaru.org/forum/topic/86790-hid-lights-on-loyale-yes-or-not-why/page-4?do=findComment&comment=760580 Kind Regards. Edited October 16, 2015 by Loyale 2.7 Turbo Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted November 18, 2015 Author Share Posted November 18, 2015 1½ years Report / Update Eighteen months have passed already since the Rear Disc Brakes' Swap, and the "KiaStein" somehow keeps braking Right, like a New car. When I did the Swap, I installed brand new Brake Pads on all four wheels; however I've never changed the Original Kia Rear Brake Pads so far, but I think that they might need to be changed soon; while the front Brake Pads were changed after a Year of use.Kind Regards. Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted November 21, 2015 Author Share Posted November 21, 2015 The only downside of not having ABS, is that under certain circumstances, the wheels could Lock during a Panic Braking; however the locking is never easy to occur, nor frequent, but somehow the Maneuver of the Sephia under Panic Braking at high Speeds, is Better with the Discs Brakes in all four wheels, because the old drums locked much easier IF they were properly adjusted. In Honduras, laws does Not require the car's owners to change their tires upon certain measurement of wear, so we use tires here, until they gets completely Bald; so, besides New tires, we have available shops that sells Used tires that comes from the USA; we believe that they has left half life still to be used. This is what happens to a tire that has more wear on its inner side, after a Full Lock Braking: Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted December 29, 2015 Author Share Posted December 29, 2015 I will Never Ever understand why people shoot Vertical Videos... Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted December 29, 2015 Author Share Posted December 29, 2015 ...In Photos is quite Different, you can use a Vertical shot to catch a whole Person... Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted December 29, 2015 Author Share Posted December 29, 2015 But a vertical photo doesn't look right on a car, see: You'll miss the Whole image and the Background. Compare that vertical photo above, with its Horizontal version Below: Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted December 29, 2015 Author Share Posted December 29, 2015 By the way, writing about photos... I shared some from the Honduran christmas seasons, here: ~► http://www.ultimatesubaru.org/forum/topic/66489-happy-holidays-with-pics/page-4 Kind Regards. Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted January 1, 2016 Author Share Posted January 1, 2016 I am Glad that I Sold this Lamp... On 10/15/2015 at 3:10 PM, Loyale 2.7 Turbo said: ... ... ...along other things, with a Good Purpose: ~► http://www.ultimatesubaru.org/forum/topic/66489-happy-holidays-with-pics/?p=1313419Kind Regards. Link to comment Share on other sites More sharing options...
