bulletsnbait Posted November 6, 2009 Share Posted November 6, 2009 Ok. So, I knew it was coming. It always happens. My loyale has 180K on it, and the rear driveshaft (it's a 4wd wagon) is getting slop. Leave it to subaru to make it so you can't change the ujoints. Anyone know where I can get a driveshaft reasonably priced? Link to comment Share on other sites More sharing options...
zyewdall Posted November 6, 2009 Share Posted November 6, 2009 No I've got a '87 GL (a friends) that needs one too, and even with the gazillion old EA82's here in Colorado, I had a hard time finding one, and it was $100 for a junkyard one a two hours drive way. Link to comment Share on other sites More sharing options...
bulletsnbait Posted November 6, 2009 Author Share Posted November 6, 2009 Shucks. See, there are ones in the junkyard here, but I figure it's just a matter of time before theyg et slop too. And subaru wants 400 for a new one. Link to comment Share on other sites More sharing options...
zyewdall Posted November 6, 2009 Share Posted November 6, 2009 Urk. I've let people send two good (okay, snapped timing belt on one, and bad starter on one... but perfectly repairable) EA82 wagons to the crushers over the years -- wish I had them as parts cars now. Link to comment Share on other sites More sharing options...
crazyman03 Posted November 6, 2009 Share Posted November 6, 2009 you actually can replace the U-joints on the shafts. Kind of a p.i.t.a. to get the old one out and the new one in. works easier if you have a hydraulic press. but it you can do it.. Didn't put the car down though. Since its FWD until you kick the 4WD in, you can still drive it. -Justin Link to comment Share on other sites More sharing options...
bulletsnbait Posted November 6, 2009 Author Share Posted November 6, 2009 How can I replace them? I mean, it looks like a solid unit to me. And, god, what part number would I sk for to get the replacement Ujoint??? Link to comment Share on other sites More sharing options...
GeneralDisorder Posted November 6, 2009 Share Posted November 6, 2009 The original U-joints were not *meant* to be replaced but it can be done. They are staked in place and so they take a bit of work to get out. The replacement's are actually for a Toyota. Any driveline shop should be able to get them and many driveline shops can do the replacement although there have been reports that some refuse to work on the EA82 shaft's They are common as dirt in the yards though so it's often easier to just get a used shaft. They don't fail very often. GD Link to comment Share on other sites More sharing options...
bulletsnbait Posted November 6, 2009 Author Share Posted November 6, 2009 Toyota what? Camry? Celica? Truck? So, can they be pressed out, or will I have to drill or punch them out? Link to comment Share on other sites More sharing options...
GeneralDisorder Posted November 6, 2009 Share Posted November 6, 2009 It's been discussed before on the board. Do a search - with the info you have now you should be able to pull up relevent threads on this topic. I don't know which Toyota's they come from - I know there's a part number floating around in some threads here though. Personally I use single-peice driveline's based on the EA81 shafts so I've never had to replace an EA82 u-joint. If you are so inclined, you can get an EA81 shaft, have it's tube lengthened to fit the EA82 tranny and then install new u-joints. GD Link to comment Share on other sites More sharing options...
bulletsnbait Posted November 6, 2009 Author Share Posted November 6, 2009 I'm reading and can't find a part number... Lots of talk about it, but no numbers. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted November 6, 2009 Share Posted November 6, 2009 Here's a post: http://www.ultimatesubaru.org/forum/showpost.php?p=62639&postcount=12 I searched for "Toyota Joint". GD Link to comment Share on other sites More sharing options...
bulletsnbait Posted November 6, 2009 Author Share Posted November 6, 2009 ok, is the Rockford driveline part the one I'm looking for? Link to comment Share on other sites More sharing options...
GeneralDisorder Posted November 6, 2009 Share Posted November 6, 2009 Yes. It's a u-joint specifically designed to replace the "non-replaceable" staked in joints. It just happens to fit mostly Toyota's from what we understand. GD Link to comment Share on other sites More sharing options...
torxxx Posted November 6, 2009 Share Posted November 6, 2009 our driveline shop up here uses mazda ujoints on the Ea82s. They were actualyl fairly cheap. 40 dollars a u joint. thats parts and labor. When one fo mine goes out, Io'm going to have them replace both of them just for the hell of it. and it is a greaseable u joint! woot lol Link to comment Share on other sites More sharing options...
crazyman03 Posted November 7, 2009 Share Posted November 7, 2009 have you tried going to checker auto or autozone? when i needed to do mine i just told them the car and that i needed a ujoint. didnt have an issue or lookup a part number. Link to comment Share on other sites More sharing options...
john in KY Posted November 8, 2009 Share Posted November 8, 2009 http://www.rockforddriveline.com/replacem.htm Link to comment Share on other sites More sharing options...
