gl2tosl2 Posted November 21, 2009 Author Share Posted November 21, 2009 Maybe swap out an ECM from a u-pick salvage yard... I just put in a ECM from a salvage yard. I let the car idle for a while and the fans came on. They weren't turning on at all before, so I think this has fixed the issue. Yay! My coolant leak is definitely getting worse and it's coming from the radiator. I've put a new cap on. If I rev the engine you can see it come out of roughly the top center of the radiator in a forward stream. I think the next step is to replace the radiator and see how everything comes out. Does this sound right? Link to comment Share on other sites More sharing options...
89Ru Posted November 22, 2009 Share Posted November 22, 2009 (edited) Glad the ECM swap worked out. Replace the radiator and hoses. Fan screws are likely to be rusted and seized, get a new set of 10mm stainless screws. Bottom fan screws only need to be loosened if the fan housing is slotted. Use an OEM thermostat (no aftermarkets) and gasket, use distilled water when you fill. Fill through the top hose, slowly to minimize air pockets. Burp the air out. Here's the basic procedure, lots of good variants around, but this will get you started. http://www.ultimatesubaru.org/forum/showthread.php?t=66821 Edited November 22, 2009 by 89Ru Link to comment Share on other sites More sharing options...
gl2tosl2 Posted November 22, 2009 Author Share Posted November 22, 2009 Glad the ECM swap worked out. Replace the radiator and hoses. Fan screws are likely to be rusted and seized, get a new set of 10mm stainless screws. Bottom fan screws only need to be loosened if the fan housing is slotted. Use an OEM thermostat (no aftermarkets) and gasket, use distilled water when you fill. Fill through the top hose, slowly to minimize air pockets. Burp the air out. Here's the basic procedure, lots of good variants around, but this will get you started. http://www.ultimatesubaru.org/forum/showthread.php?t=66821 I put the new radiator in this morning. Burping seemed to go all right. I'll keep an eye on it for a while. At this point, the fans are working and there are no external coolant leaks. Thanks for the help. Link to comment Share on other sites More sharing options...
johnceggleston Posted November 22, 2009 Share Posted November 22, 2009 I put the new radiator in this morning. Burping seemed to go all right. I'll keep an eye on it for a while. At this point, the fans are working and there are no external coolant leaks. Thanks for the help. sounds good, check back in after a while and let us know how it is going. Link to comment Share on other sites More sharing options...
