dcbpe Posted November 10, 2009 Share Posted November 10, 2009 I'm looking for advice on what needs to be done to store my Outback until Spring. I have a head gasket problem that I have neither the time, space, nor money to fix. So, I'm wondering what I need to do in order to protect the car from deteriorating while it sits outside all winter. Just cover it, put it up on blocks, drain the fluids, etc.? BTW, it has brand new oil/filter, and a full tank of gas. Link to comment Share on other sites More sharing options...
Fairtax4me Posted November 10, 2009 Share Posted November 10, 2009 Put a bottle or two of fuel stabilizer in the tank. Throw a cover over it. The rest will be dealt with after coming out of storage. Link to comment Share on other sites More sharing options...
ericem Posted November 10, 2009 Share Posted November 10, 2009 Also wash the car really well especially the fenders and underbody, then get some rust spray and go nuts on w/e seemed possible to rust or is rusting. Some ideas, fuel tank components, gaps, fenders, etc. Link to comment Share on other sites More sharing options...
dcbpe Posted November 11, 2009 Author Share Posted November 11, 2009 Thanks guys, I thought it might be more involved than that. Link to comment Share on other sites More sharing options...
hankosolder2 Posted November 11, 2009 Share Posted November 11, 2009 I'd say that if it has a HG problem, you really should "fog" the engine cylinders with oil. If the coolant isn't completely drained and seeps into the combustion chambers, you could ruin the engine. (Yes, I know that the failure mode for these HG is combustion gasses>coolant, but under extended storage it's possible it could seep in the other direction.) Nathan Link to comment Share on other sites More sharing options...
dcbpe Posted November 11, 2009 Author Share Posted November 11, 2009 hankosolder2 said: I'd say that if it has a HG problem, you really should "fog" the engine cylinders with oil. If the coolant isn't completely drained and seeps into the combustion chambers, you could ruin the engine. (Yes, I know that the failure mode for these HG is combustion gasses>coolant, but under extended storage it's possible it could seep in the other direction.) Nathan "Fog" the cylinders? How does one do that? Right now the coolant system is drained. I was preparing to run some of that steel seal stuff through the system and see if I could get the car working, but stopped after two water flushes based on advice received here at the forums. Link to comment Share on other sites More sharing options...
valvestem Posted November 11, 2009 Share Posted November 11, 2009 dcbpe said: "Fog" the cylinders? How does one do that? Fogging the cylinders is a common term for prepping them for long term storage by coating them with a "fogging oil" usually introduced through the intake at some point, while the engine is running. The fogging prevents corrosion. It is standard practice for outboard motors, snow blower engines, lawn mower engines and motorcycles as well, any engine used seasonally and then stored for a long time. Used in conjunction with a gas treatment such as Sta-Bil etc. Link to comment Share on other sites More sharing options...
nipper Posted November 12, 2009 Share Posted November 12, 2009 valvestem said: Fogging the cylinders is a common term for prepping them for long term storage by coating them with a "fogging oil" usually introduced through the intake at some point, while the engine is running. The fogging prevents corrosion. It is standard practice for outboard motors, snow blower engines, lawn mower engines and motorcycles as well, any engine used seasonally and then stored for a long time. Used in conjunction with a gas treatment such as Sta-Bil etc. +1 You can actually by a spray bottle of engine fog OR just squirt some oil in the cylinders and crank the engine over, dont let it start. Do this after putting stabil in the fuel and letting the car run for a bit to circulate it. Put the car up on blocks to prevent flat spots in the tires. I have some concern of the car sitting that long with a bad hg that has contaminated coolant. It may clog the radiator with time (and then again may not). If the battery is in good condition, put a small trickle charger on it or move it inside someplace warm to keep it happy. recharge the battery before using if it isnt being trickle charged. Do not set the parking brake, the pads may rust to the rotors. nipper Link to comment Share on other sites More sharing options...
