Pic Request: Loyale/GL Shifter
Hey guys, I have a special situation where I need to modify the shifter on my '91 Loyale (5mt push-button 4wd) due to a physical disability. I need to extend the shifter up approx 9" and back approx 6". In doing so, I fear the shift throw will be super long.
So, I'd like to install a Kartboy short shifter to decrease the throw. I asked Tom @ Kartboy to see if their shifter will work with the 5mt, but he needs a pic or two to confirm that it'll work/fit.
Does anyone have pics of the shifter without the boot??
TIA!
Ian
The shifter on the push-button 4WD is a bit different than those used on the EJ series transmissions. The 4WD shift assembly uses a "shelf" that contains the pivot point for the shifter as well as the D/R shift lever for the older non-pushbutton style transmissions.
If I were you, and wanted to use the kart-boy stuff, I would probably just switch over to the entire EJ shift linkage system. You would have to mount the rubber "sling" for the pivot rod but that wouldn't take a lot of fab work. Being that you don't need the shelf to mount the D/R lever to it shouldn't be that big of a deal.
Cool, keep us updated on the project!!:banana:
I definitely will! I'm talking to a vendor on Nasioc to have a special extension made to my specs... :) I just need to find the time to take all of the measurements and tie up loose ends, so I can take the car home.
The laundry list is:
Shifter Extension
Shift Knob
Shift Boot (maybe)
Relocate 4WD button to dash using the cruise control button.
Install tilt steering column and swap ignitions.
Thoroughly clean the car and enjoy! :)
After the shifter extension is figured out the rest should be cake. I might install some Hella 500s while I'm at it!
I'm getting some fantastic help from a vendor on NASION called WC Lathe Werks, who makes custom knobs and shifter extensions.
I put together a rendering of the shifter and knob. I can't wait to drive this car! Should be just in time for the Hatch Patrol Christmas Tree Run.
