Anyone else use the LATCH in the center?
I know this is slightly OT, but often the LATCH anchors have a weight limit (40Lbs?) and often the car seat will have its own lower weight limit when using LATCH anchors. (The lower of the two weights limits is the limit for that seat/car combo.)
My feeling is that since regular belts do not have a weight limit, I'll take a properly adjusted standard belt over LATCH fasteners. Stronger is stronger.
If you want to research, go to car-seat.org - those people are FANATICS, so they'll probably tell you your kid(s) will die in a ball of fire if you deviate from the installation instructions one iota.
Nathan
right, i'm not partial to emo arm chair commentators like that. Edited by grossgary
